Hi there,
i want you to help me deciding what board i may use for my new project. here is the list of features i will ask the arduino board:
1x Step-motor
1x DC motor
10x leds
10x switch buttons
1x old screen
my doubt is about what board using, but also if it will be necessary to use 2 boards in the same project, please, clear my doubts, thanks a lot
Have a nice day
you need to total up your IO requirements, e.g. to interfacing modules such as OLED display, stepper motor, DC motor, etc can often require several pins - also consider how you will power the system
what extra functionality may you require in the future
avoid having to use two boards - having to program two microcontrollers and the resultant communications makes the overall task complexity an order of magnitude greater
Thank you Horace,
i was looking at Mux or Multiplexers, i suppose that is what you mean as IO extenders...
i do understand that one board is better than 2, ...
thanks for the links, very useful!
The last point about the power supply will be for a new topic on the forum, but yes, that will be the tricky part.
