This is primarily for investigating algorithms and data structures, not for hardware I/O.
Having a proper debugger is important as I really miss what you can do with Intellij based Java/Kotlin/Python style environments.
Also, it would be handy to have some kind of switchable 8/32 bit emulation mode to see what effects that has on the way things are stored in memory.
You might give VS Code a look. I don't do a lot of native C++ programming in it, but when I do I find everything works without difficulties, including the debugger.
I'm using this extension to add full C++ support to VS Code:
VS Code is an excellent free open source editor/IDE for pretty much any language so there is a good chance you'll end up finding it useful for more than C++ alone.
The Arduino IDE 2.x UI is built on a framework based on VS Code, so you will find that you have been somewhat familiarized to the VS Code UI by prior use of Arduino IDE 2.x, and vice versa.
