What can be with this TFT lcd?
Hi all.
the ESP32 + ILI9341 failed at calibration, and left a 2/3 working area. what's wrong about?
Thanks
Adam
  Sketch to generate the setup() calibration values, these are reported
  to the Serial Monitor.
  The sketch has been tested on the ESP8266 and screen with XPT2046 driver.
#include <SPI.h>
#include <TFT_eSPI.h>      // Hardware-specific library
TFT_eSPI tft = TFT_eSPI(); // Invoke custom library
  // Use serial port
  // Initialise the TFT screen
  tft.init();
  // Set the rotation to the orientation you wish to use in your project before calibration
  // (the touch coordinates returned then correspond to that rotation only)
  tft.setRotation(1);
  // Calibrate the touch screen and retrieve the scaling factors
  touch_calibrate();
  // Replace above line with the code sent to Serial Monitor
  // once calibration is complete, e.g.:
  uint16_t calData[5] = { 286, 3534, 283, 3600, 6 };
  tft.setTouch(calData);
  // Clear the screen
  tft.fillScreen(TFT_BLACK);
  tft.drawCentreString("Touch screen to test!",tft.width()/2, tft.height()/2, 2);
void loop(void) {
  uint16_t x = 0, y = 0; // To store the touch coordinates
  // Pressed will be set true is there is a valid touch on the screen
  bool pressed = tft.getTouch(&x, &y);
  // Draw a white spot at the detected coordinates
  if (pressed) {
    tft.fillCircle(x, y, 2, TFT_WHITE);
    //Serial.print("x,y = ");
    //Serial.print(x);
    //Serial.print(",");
    //Serial.println(y);
// Code to run a screen calibration, not needed when calibration values set in setup()
void touch_calibrate()
  uint16_t calData[5];
  uint8_t calDataOK = 0;
  // Calibrate
  tft.setCursor(20, 0);
  tft.setTextFont(2);
  tft.setTextSize(1);
  tft.setTextColor(TFT_WHITE, TFT_BLACK);
  tft.println("Touch corners as indicated");
  tft.setTextFont(1);
  tft.println();
  tft.calibrateTouch(calData, TFT_MAGENTA, TFT_BLACK, 15);
  Serial.println(); Serial.println();
  Serial.println("// Use this calibration code in setup():");
  Serial.print("  uint16_t calData[5] = ");
  Serial.print("{ ");
  for (uint8_t i = 0; i < 5; i++)
    Serial.print(calData[i]);
    if (i < 4) Serial.print(", ");
  Serial.println(" };");
  Serial.print("  tft.setTouch(calData);");
  tft.setTextColor(TFT_GREEN, TFT_BLACK);
  tft.println("Calibration complete!");
  tft.println("Calibration code sent to Serial port.");
  delay(4000);
..0
Which touchscreen controller do you have?
Thanks.
XPT2046.
