#include <Adafruit_GFX.h>
#include <Adafruit_GrayOLED.h>
#include <Adafruit_SPITFT.h>
#include <Adafruit_SPITFT_Macros.h>
#include <gfxfont.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <WiFiServer.h>
#include <WiFiUdp.h>
#include <ESP8266HTTPClient.h>
#include <ArduinoJson.h>
#include <SerialESP8266wifi.h>
#include <Arduino_JSON.h>
#include <JSON.h>
#include <JSONVar.h>
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <splash.h>
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h> // http web access library
#include <ArduinoJson.h> // JSON decoding library
// Libraries for SSD1306 OLED display
#include <Wire.h> // include wire library (for I2C devices such as the SSD1306 display)
#include <Adafruit_GFX.h> // include Adafruit graphics library
#include <Adafruit_SSD1306.h> // include Adafruit SSD1306 OLED display driver
#define OLED_RESET 5 // define SSD1306 OLED reset at ESP8266 GPIO5 (NodeMCU D1)
Adafruit_SSD1306 display(OLED_RESET);
// set Wi-Fi SSID and password
const char *ssid = "TP-Link_6742";
const char *password = "26051973";
// set location and API key
String Location = "Amravati, IN";
String API_Key = "eb9274010b722f75502bbf8fa15f4872";
Wire.begin(4, 0); // set I2C pins [SDA = GPIO4 (D2), SCL = GPIO0 (D3)], default clock is 100kHz
// by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3D (for the 128x64)
// init done
Wire.setClock(400000L); // set I2C clock to 400kHz
display.clearDisplay(); // clear the display buffer
display.setTextColor(WHITE, BLACK);
display.setTextSize(1);
display.setCursor(0, 0);
display.println("Weather News By Anupam");
display.print(" Station - Amravati");
display.display();
WiFi.begin ("ssid, password");
Serial.print("Connecting.");
display.setCursor(0, 24);
display.println("Connecting...");
display.println("Made By Anupam");
display.display();
while ( WiFi.status() != WL_CONNECTED )
Serial.print(".");
Serial.println("connected");
display.print("connected");
display.display();
if (WiFi.status() == WL_CONNECTED) //Check WiFi connection status
HTTPClient http; //Declare an object of class HTTPClient
// specify request destination
http.begin("http://api.openweathermap.org/data/2.5/weather?q=" + Location + "&APPID=" + API_Key); // !!
int httpCode = http.GET(); // send the request
if (httpCode > 0) // check the returning code
String payload = http.getString(); //Get the request response payload
DynamicJsonBuffer jsonBuffer(512);
// Parse JSON object
JsonObject& root = jsonBuffer.parseObject(payload);
if (!root.success()) {
Serial.println(F("Parsing failed!"));
return;
float temp = (float)(root["main"]["temp"]) - 273.15; // get temperature in °C
int humidity = root["main"]["humidity"]; // get humidity in %
float pressure = (float)(root["main"]["pressure"]) / 1000; // get pressure in bar
float wind_speed = root["wind"]["speed"]; // get wind speed in m/s
int wind_degree = root["wind"]["deg"]; // get wind degree in °
// print data
Serial.printf("Temperature = %.2f°C\r\n", temp);
Serial.printf("Humidity = %d %%\r\n", humidity);
Serial.printf("Pressure = %.3f bar\r\n", pressure);
Serial.printf("Wind speed = %.1f m/s\r\n", wind_speed);
Serial.printf("Wind degree = %d°\r\n\r\n", wind_degree);
display.printf("Temperature: %5.2f C\r\n", temp);
display.printf("Humidity : %d %%\r\n", humidity);
display.printf("Pressure : %.3fbar\r\n", pressure);
display.printf("Wind speed : %.1f m/s\r\n", wind_speed);
display.printf("Wind degree: %d", wind_degree);
display.drawRect(109, 24, 3, 3, WHITE); // put degree symbol ( ° )
display.drawRect(97, 56, 3, 3, WHITE);
display.display();
http.end(); //Close connection
delay(60000); // wait 1 minute
// End of code.
In file included from C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266WiFi\src/WiFiClientSecure.h:41:0,
from C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266WiFi\src/WiFiServerSecure.h:20,
from C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266WiFi\src/ESP8266WiFi.h:41,
from C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266HTTPClient\src\ESP8266HTTPClient.cpp:29:
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:38:5: error: 'BearSSL::WiFiClientSecure::~WiFiClientSecure()' marked override, but does not override
~WiFiClientSecure() override;
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:43:9: error: 'int BearSSL::WiFiClientSecure::connect(const String&, uint16_t)' marked override, but does not override
int connect(const String& host, uint16_t port) override;
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:48:12: error: 'size_t BearSSL::WiFiClientSecure::write_P(const char*, size_t)' marked override, but does not override
size_t write_P(PGM_P buf, size_t size) override;
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:60:12: error: 'size_t BearSSL::WiFiClientSecure::peekBytes(uint8_t*, size_t)' marked override, but does not override
size_t peekBytes(uint8_t *buffer, size_t length) override;
In file included from C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266HTTPClient\src\ESP8266HTTPClient.cpp:30:0:
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266WiFi\src/WiFiClientSecureAxTLS.h:36:3: error: 'axTLS::WiFiClientSecure::~WiFiClientSecure()' marked override, but does not override
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266WiFi\src/WiFiClientSecureAxTLS.h:39:7: error: 'int axTLS::WiFiClientSecure::connect(const String&, uint16_t)' marked override, but does not override
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266WiFi\src/WiFiClientSecureAxTLS.h:47:10: error: 'size_t axTLS::WiFiClientSecure::write_P(const char*, size_t)' marked override, but does not override
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266WiFi\src/WiFiClientSecureAxTLS.h:53:10: error: 'size_t axTLS::WiFiClientSecure::peekBytes(uint8_t*, size_t)' marked override, but does not override
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266HTTPClient\src\ESP8266HTTPClient.cpp: In member function 'bool HTTPClient::connect()':
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266HTTPClient\src\ESP8266HTTPClient.cpp:1248:14: error: 'class WiFiClient' has no member named 'setNoDelay'
_client->setNoDelay(true);
exit status 1
Error compiling for board Generic ESP8266 Module.
option enabled in File -> Preferences.
This Is The Error
You can re-write the sketch using the current libraries. Here I have done it for you. It compiles for an ESP8266 but I don't have one to test on so I can't be sure it works. Give it a try.
#include <ESP8266WiFiMulti.h>
ESP8266WiFiMulti WiFiMulti;
// init done
display.display();
WiFi.mode(WIFI_STA);
WiFiMulti.addAP(ssid, password);
display.display();
Serial.print(".");
display.display();
// wait for WiFi connection
if ((WiFiMulti.run() == WL_CONNECTED))
WiFiClient client;
HTTPClient http;
String payload;
Serial.print("[HTTP] begin...\n");
if (http.begin(client, "http://api.openweathermap.org/data/2.5/weather?q=" + Location + "&APPID=" + API_Key)) // HTTP
Serial.print("[HTTP] GET...\n");
// start connection and send HTTP header
// httpCode will be negative on error
// HTTP header has been send and Server response header has been handled
Serial.printf("[HTTP] GET... code: %d\n", httpCode);
// file found at server
if (httpCode == HTTP_CODE_OK || httpCode == HTTP_CODE_MOVED_PERMANENTLY)
// Serial.println(payload);
Serial.printf("[HTTP] GET... failed, error: %s\n",
http.errorToString(httpCode).c_str());
return;
{"coord":{"lon":77.75,"lat":20.9333},
"weather":[{"id":804,"main":"Clouds","description":"overcast clouds","icon":"04n"}],
"base":"stations","main":{"temp":301.45,"feels_like":303.3,"temp_min":301.45,
"temp_max":301.45,"pressure":1004,"humidity":62,"sea_level":1004,"grnd_level":966},
"visibility":10000,"wind":{"speed":3.14,"deg":293,"gust":7.39},"clouds":{"all":94},
"dt":1628958953,"sys":{"country":"IN","sunrise":1628900858,"sunset":1628947200},
"timezone":19800,"id":1278718,"name":"Amrāvati","cod":200}
StaticJsonDocument<1024> doc;
DeserializationError error = deserializeJson(doc, payload);
if (error)
Serial.print(F("deserializeJson() failed: "));
Serial.println(error.f_str());
return;
// float coord_lon = doc["coord"]["lon"]; // 77.75
// float coord_lat = doc["coord"]["lat"]; // 20.9333
// JsonObject weather_0 = doc["weather"][0];
// int weather_0_id = weather_0["id"]; // 804
// const char* weather_0_main = weather_0["main"]; // "Clouds"
// const char* weather_0_description = weather_0["description"]; // "overcast clouds"
// const char* weather_0_icon = weather_0["icon"]; // "04n"
// const char* base = doc["base"]; // "stations"
JsonObject main = doc["main"];
float main_temp = main["temp"]; // 301.45
// float main_feels_like = main["feels_like"]; // 303.3
// float main_temp_min = main["temp_min"]; // 301.45
// float main_temp_max = main["temp_max"]; // 301.45
float main_pressure = main["pressure"]; // 1004
int main_humidity = main["humidity"]; // 62
// int main_sea_level = main["sea_level"]; // 1004
// int main_grnd_level = main["grnd_level"]; // 966
// int visibility = doc["visibility"]; // 10000
JsonObject wind = doc["wind"];
float wind_speed = wind["speed"]; // 3.14
int wind_deg = wind["deg"]; // 293
// float wind_gust = wind["gust"]; // 7.39
// int clouds_all = doc["clouds"]["all"]; // 94
// long dt = doc["dt"]; // 1628958953
// JsonObject sys = doc["sys"];
// const char* sys_country = sys["country"]; // "IN"
// long sys_sunrise = sys["sunrise"]; // 1628900858
// long sys_sunset = sys["sunset"]; // 1628947200
// int timezone = doc["timezone"]; // 19800
// long id = doc["id"]; // 1278718
// const char* name = doc["name"]; // "Amrāvati"
// int cod = doc["cod"]; // 200
// print data
Serial.printf("Temperature = %.2f°C\r\n", main_temp);
Serial.printf("Humidity = %d %%\r\n", main_humidity);
Serial.printf("Pressure = %.3f bar\r\n", main_pressure);
Serial.printf("Wind degree = %d°\r\n\r\n", wind_deg);
display.printf("Temperature: %5.2f C\r\n", main_temp);
display.printf("Humidity : %d %%\r\n", main_humidity);
display.printf("Pressure : %.3fbar\r\n", main_pressure);
display.printf("Wind degree: %d", wind_deg);
display.display();
// End of code.
