What can I do with these IR sensor results??
With the code that I found on this page, the IR-receiver reacts perfectly on my IR remote conol. But with a lot of data!
My question is: how can I be able to control for example a car with my IR remote with a block of information like this (see ned of message). I thought it would be just a code of something like 10 digits that I can use in a switch case statement. So I'm wrong I guess...
Thanks for your help in advance!
Bram
4 0
9032 0
9032 1
13472 1
13472 0
14056 0
14056 1
15708 1
15708 0
16288 0
16288 1
16824 1
16824 0
17408 0
17408 1
17932 1
17932 0
18524 0
18524 1
19040 1
19040 0
19640 0
19640 1
20164 1
20164 0
20760 0
20760 1
21296 1
21296 0
21876 0
21876 1
22412 1
22412 0
22996 0
22996 1
23508 1
23508 0
24112 0
24112 1
25768 1
25768 0
26348 0
26348 1
26864 1
26864 0
27464 0
27464 1
29120 1
29120 0
29700 0
29700 1
31352 1
31352 0
31932 0
31932 1
33584 1
33584 0
34172 0
34172 1
35824 1
35824 0
36408 0
36408 1
38060 1
38060 0
38640 0
38640 1
40296 1
40296 0
40876 0
40876 1
41416 1
41416 0
41992 0
41992 1
43640 1
43640 0
44232 0
44232 1
44768 1
44768 0
45348 0
45348 1
45884 1
45884 0
46468 0
46468 1
48080 1
48080 0
48700 0
48700 1
49236 1
49236 0
49816 0
49816 1
51448 1
51448 0
52052 0
52052 1
53700 1
53700 0
54284 0
54284 1
55944 1
55944 0
56520 0
56520 1
57060 1
57060 0
57644 0
57644 1
59276 1
59276 0
59876 0
59876 1
61532 1
61532 0
62108 0
62108 1
62648 1
62648 0
63228 0
63228 1
64884 1
64884 0
65464 0
65464 1
Bit stream end!
Post your code. It looks like your dump output has two components: the IR key code, and the start/stop of the detection. I think a switch statement would be a good starting point.
If you can write a switch on the key codes, you can easily add forward/reverse/left/right commands. And if you pair that with the start/stop portion, your switch statement will be able to cancel each of the commands you write. That would be a good start, I would think.
Hi, with the sketch from the IRremote library I was able to get short HEX-values, wich can be converted here (Redirect Notice) to get decimal values. Now I am able to control a led with my remote control.
Thanks for your help!
Some examples and background details here:
http://arduino-info.wikispaces.com/IR-RemoteControl
