What card to use : Scale and Pump Application
Hello,
I'm trying to make a dispenser that controls a pump using an electrical/pneumatic solenoid for an output to my pump/valve, with input coming from a serial (RS232 Comm) scale.
Basically, I want to set the dispense variable using a num pad and LED display, and then a "GO" button to start the process.
When the scale reaches the dispense variable (7kg eg.) the process stops and the pump/valve close.
What arduino board am I looking for? I feel this is a pretty basic function, but I want a card that'll last a while with repeated use. The most complicated thing I think is the serial communication, but I can get an RS232 to USB adapter for that since I've seen a number of Arduino's have USB ports.
I'll try to answer any questions that will help clarify my requirements.
Thanks in advance for the help!
With very few inputs and very few outputs, any model will work.
