Rank amateur here, hoping someone can point me in the right direction.
I need some kind of switching circuit, here are my parameters:
- I need a voltage (12v) running to either fan A or fan B (either way one fan is always on).
- When a signal is sent down line A (5v) I need fan A to turn on, and fan B to turn off.
- When a signal is sent down line B (5v) I need fan B to turn on, and fan A to turn off.
- BUT when the signal stops on either lines, I need that last fan that was switched on to stay on.
I cannot control the incoming signal. It's part of an existing arduino project that I can't change it's software, I just sort of want to 'tap into the pins' with a custom shield with my circuit. The signal down lines A and B is always either/or, never at the same time.
Is there a way to do this with ordinary components from radioshack? (without another microcontroller)
Right now the only way I can think of is to program another microcontroller, like an attiny, to control a pair of fets. That would be easy enough for me to execute but requires mail order.
