Here is the updated code (see also attached file) :
#include "DHT.h"
#include "NewPing.h"
#include <SoftwareSerial.h>
#define DEBUG true
SoftwareSerial esp8266(11,10);
SoftwareSerial gps(8,9);
#define DHTPIN 2 // DHT-11 Output Pin connection
#define DHTTYPE DHT11 // DHT Type is DHT 11 (AM2302)
#define TRIGGER_PIN 4
#define ECHO_PIN 3
#define MAX_DISTANCE 400
NewPing sonar(TRIGGER_PIN,ECHO_PIN,MAX_DISTANCE);
float hum;
float temp;
DHT dht(DHTPIN, DHTTYPE);
Serial.begin (9600);
Serial.println("START");
esp8266.begin(9600);
gps.begin(9600);
dht.begin();
pinMode(TRIGGER_PIN, OUTPUT);
pinMode(ECHO_PIN, INPUT);
sendData("AT+RST\r\n",2000,DEBUG); // command to reset the module
sendData("AT+CWMODE=2\r\n",1000,DEBUG); // This will configure the mode as access point
sendData("AT+CIFSR\r\n",1000,DEBUG); // This command will get the ip address
sendData("AT+CIPMUX=1\r\n",1000,DEBUG); // This will configure the esp for multiple connections
sendData("AT+CIPSERVER=1,80\r\n",1000,DEBUG); // This command will turn on the server on port 80
delay(2000); // Delay so DHT-11 sensor can stabalize
hum = dht.readHumidity(); // Get Humidity value
temp= dht.readTemperature(); // Get Temperature value
digitalWrite(TRIGGER_PIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIGGER_PIN, HIGH);
delayMicroseconds(10);
long duration,distance;
duration= pulseIn(ECHO_PIN,HIGH);
distance = duration/58.2;
Serial.print("Humid: ");
Serial.print(hum);
Serial.print(" %, Temp: ");
Serial.print(temp);
Serial.print(" C, ");
Serial.print("Distance: ");
Serial.print(distance);
Serial.println(" cm");
delay(50);
while (gps.available())
Serial.write(gps.read());
if(esp8266.available()) // This command will that check if the esp is sending a message
if(esp8266.find("+IPD,"))
int connectionId = esp8266.read()-48; /* We are subtracting 48 from the output because the read() function returns
the ASCII decimal value and the first decimal number which is 0 starts at 48*/
String webpage = "<meta http-equiv="refresh" content="5; url=192.168.4.1/">";
webpage += "
Mabalacat City College Garbage Monitoring System
webpage += "
if (distance<=5)
webpage+= " Trash can is Red";
if (distance == 20)
webpage+= " Trash can is Orange";
if (distance == 35)
webpage+= " Trash can is Light Orange";
if (distance == 50)
webpage+= " Trash can is Yellow";
if (distance == 70)
webpage+= " Trash can is 2st Light Yellow";
if (distance == 85)
webpage+= " Trash can is 1st Light Yellow";
if (distance == 95)
webpage+= " Trash can is Green";
if (distance >= 100)
webpage+= " Trash can is Empty";
webpage+= "
webpage+="Distance: ";
webpage+=distance;
webpage+=" cm";
webpage+= "
webpage+="Temperature: ";
webpage+= temp;
webpage+=" celsius";
webpage+= "
webpage+= "Humidity: ";
webpage+= hum;
webpage+= " %";
webpage += "
String cipSend = "AT+CIPSEND=";
cipSend += connectionId;
cipSend += ",";
cipSend +=webpage.length();
cipSend +="\r\n";
sendData(cipSend,1000,DEBUG);
sendData(webpage,1000,DEBUG);
String closeCommand = "AT+CIPCLOSE=";
closeCommand+=connectionId;
closeCommand+="\r\n";
sendData(closeCommand,3000,DEBUG);
String sendData(String command, const int timeout, boolean debug)
String response = "";
esp8266.print(command);
long int time = millis();
while( (time+timeout) > millis())
while(esp8266.available())
char c = esp8266.read();
response+=c;
if(debug)
Serial.print(command);
Serial.print("> ");
Serial.print(response);
return response;
= = = = =The output = = = = =
START
AT+RST
AT+CWMODE=2
AT+CIFSR
AT+CIPMUX=1
AT+CIPSERVER=1,80
Humid: 67.00 %, Temp: 31.00 C, Distance: 150 cm
Humid: 67.00 %, Temp: 30.00 C, Distance: 26 cm
Humid: 67.00 %, Temp: 30.00 C, Distance: 151 cm
Humid: 67.00 %, Temp: 30.00 C, Distance: 150 cm
Humid: 67.00 %, Temp: 30.00 C, Distance: 149 cm
Humid: 67.00 %, Temp: 30.00 C, Distance: 3501 cm
Humid: 68.00 %, Temp: 31.00 C, Distance: 13 cm
Humid: 67.00 %, Temp: 30.00 C, Distance: 3467 cm
Humid: 68.00 %, Temp: 31.00 C, Distance: 149 cm
Humid: 66.00 %, Temp: 30.00 C, Distance: 149 cm
arduino code.txt (4.49 KB)
arduino ouput.txt (861 Bytes)
