What could I be doing wrong?
It seems like a simple thing but I not sure what Im doing wrong. I building a controller for a traffic light that I want to hang in the garage. Im using a standard atmega 168 programmed with an arduino board. Im using 3 digital pins to control a relay board. The problem that Im having is that the lights don't always turn off when the pin goes low. Here is the program that im using:
/* YourDuino Example: Relay Control 1.10
Handles "Relay is active-low" to assure
no relay activation from reset until
application is ready.
terry@yourduino.com */
/-----( Import needed libraries )-----/
/-----( Declare Constants )-----/
#define RELAY_ON 0
#define RELAY_OFF 1
/-----( Declare objects )-----/
/-----( Declare Variables )-----/
#define Relay_1 2 // Arduino Digital I/O pin number
#define Relay_2 3
#define Relay_3 4
void setup() /****** SETUP: RUNS ONCE ******/
//-------( Initialize Pins so relays are inactive at reset)----
digitalWrite(Relay_1, RELAY_OFF);
digitalWrite(Relay_2, RELAY_OFF);
digitalWrite(Relay_3, RELAY_OFF);
//---( THEN set pins as outputs )----
pinMode(Relay_1, OUTPUT);
pinMode(Relay_2, OUTPUT);
pinMode(Relay_3, OUTPUT);
delay(4000); //Check that all relays are inactive at Reset
}//--(end setup )---
void loop() /****** LOOP: RUNS CONSTANTLY ******/
//---( Turn all 4 relays ON in sequence)---
digitalWrite(Relay_1, RELAY_ON);// set the Relay ON
delay(60000); // wait for a second
digitalWrite(Relay_1, RELAY_OFF);// set the Relay OFF
delay(1);
digitalWrite(Relay_2, RELAY_ON);// set the Relay ON
delay(10000); // wait for a second
digitalWrite(Relay_2, RELAY_OFF);// set the Relay OFF
delay(1);
digitalWrite(Relay_3, RELAY_ON);// set the Relay ON
digitalWrite(Relay_3, RELAY_OFF);// set the Relay OFF
delay(1);
}//--(end main loop )---
//( THE END )**
Any help would be much appreciated!
Thanks,
Tracy
Sounds like a wiring problem rather than a code problem. How are the relays connected to the Arduino?
here is a pic...pretty straight forward I think!
The wiring looks OK but prototype boards are fairly notorious for bad connections. I would try a simpler sketch that turns all the relays on. Then you can wiggle wires to see if a connection is loose.
Yeah... Are you sure the pin is going low? If the pins are switching as you expect, it's not a software problem.... Are you checking the output pins with a meter, or an LED or something?
Just my opinion, but I'd change that comment, since "a" second implies "one" second.
It's obviously a delay, even if you don't understand the Arduino programming language. So, if you don't want to put the actual time in the comment, you can delete the comment. Or, maybe change it to: "//delay(milliseconds)". Or, indicate the purpose for the delay: "//Leave green light on for 60 seconds"
Thanks for the replies guys....
John
Think Im going to go ahead and solde up a stand alone Arduino to eliminate the chances of a bad connection.
Doug,
That was some canned code from the site that sells the board. I was playing around with the delays to get the timing down for the light. It seems that I can lightly tap the relay after it the Arduino goes low and the contacts will go open. I have tried a meter and an led with a battery.
Tracy
Im starting to think that these Songle relays are junk....It seems that I cap tap them after they are de-energized and all goes good.
I think you are right. I think it's a "sticky" relay.
As a possible "quick-and-dirty" fix - If it works sometimes, try "exercising" the relays by turning them on & off rapidly (maybe 100mS) with no load attached. Let it run for 1000 cycles or so. If there's some corrosion on the contacts, that may clean it off. Of course if it's not working at all, then it cannot be exercised.
Quite often, this will work. If this works, it might be a permanent fix, or it might be a short-term fix... In any case I wouldn't use that relay in a medical device. :smiley:
When the relay is off, it should always be off, but it's possible to partially energize a relay if there's something wrong with the electronics or if the output switches on & off at a very fast rate, like how PWM works.
beerbarrel:
Do the relays stay closed if you remove power from the whole system? If so I suggest you get your money back.
That depends on the relay contact specification, and the applied load.
No Peter they did not....good point!
I have to give credit where credit is due. Thanks Johnwasser! It was indeed loose connections at the perf board. It seems that if I have a loose connection the board never gets the signal to go low and turn relay off. Repaired connections and works like a charm! Thanks for all the help guys!
Tracy
That look like a nice board that I need to build. Did the board include a resistor at the base of the transistor ? I saw LED's on this board...one green <-- power indicator ? and 4 red one <-- relay indicator ? On - relay active Off - relay off. I saw 4 transistors and 4 diode , limiting resistors for the leds, and the relay are rated at 10 A. And big headers... Interesting
I'm surprised nobody has yet pointed out that there is no decoupling capacitor on the breadboard for the atmega328 chip.
dc42:
There are two load capacitors for the crystal - is there supposed to be another one somewhere? What should it be decoupling?
There should be at least one 0.1uF ceramic capacitor between the Vcc and Gnd pins of the mcu, as close to the mcu as reasonable possible.
Welp,
Back to square one! Soldered up the circuit and have basically the same issue I had before. The relays will each energize in turn and stay energized until power is removed from the circuit. I had it working ok last night but after soldering it up it does just as described. I added the decoupling cap between the power and ground but it did not help. Im running out of ideas here Any help would be much appreciated. All pins are connected correctly and there are no solder bridges.
Thanks guys,
Tracy
First.
Can you please try this test code. You have to change the pins numbers to fit your hardware setup/connection.
The code compile, but not tested...
const boolean RELAY_ON = 0;
const boolean RELAY_OFF = 1;
const int Relay_1 = 2;  // Arduino Digital I/O pin number
const int Relay_2 = 3;
const int Relay_3 = 4;
const int Relay_4 = 5;
  pinMode(Relay_4, OUTPUT);
  digitalWrite(Relay_4, RELAY_OFF);
  delay(1000);              // wait for a second
  digitalWrite(Relay_4, RELAY_ON);
FYI: the Arduino-Direct.com site has a schematic for this board:
http://arduino-direct.com/sunshop/index.php?l=product_detail&p=155
Each relay has PNP transistor acting as a high-side switch. There are 1K resistors between the inputs (Arduino pins) and the base of the transistors.
Techone - Tried it with no luck. I also tried to use my arduino board and I get the same thing. Im guessing these relay boards could be the issue. I can tap the relays lightly and make the contacts open. It seems like something is keeping them engaged.
Thanks for the link johnwasser
Johnwasser - that is the place that I bought the board from. Funny thing that I have noticed. Diodes d1-d4 stay lite dimly when that pin is not energized. I'm thinking that there is enough current to keep the replays energized. You can hear the relays dis engage as soon as you pull the power.
Tracy
