What do I need for running stepper motors?
Requirements:
  • I would like to control two stepper motors.
  • It should be connect wireless to the internet
  • It should be possible to power the stepper motors with a battery
  • Do I need an extra module if I want to control all actions with my own mobile app?
Which board or boards do I need ?
Any help would be amazing.
Stepper motor projects start by choosing a motor with the required power and torque (and possibly, gear ratio) to do the expected mechanical things.
Then choose a motor driver and power supply that can handle the motor.
Any Arduino can be used to control the motor driver, and you will find countless tutorials on line for that.
Since you want internet connectivity in your project, you can consider ESP-32. ESP 32: How to Control Stepper Motors - YouTube
Thanks.
Which Arduino do I need after I chose the stepper motor, motor driver and power supply?
Does every board works to control it with my own app?
As mentioned in post #2.
Welcome!
Just "some" links:
Thank you very much for the links. @tinkerer9 :muscle:t2:
@jremington okay got it but what about my question to control it with my own app?
Do I need here a separate modul as well like for the motor ?
Or are there some boards available who has that integration already?
That's the main thing to do. Selcting a suitable driver is highly dependent on the selected motor.
And you should not use one of the ancient L29x drivers.
Okay thank.
Can you recommend a suitable driver with smotor ?
The stepper has to turn a table with max. 1kg.
If you have a working system please share it. :grimacing:
? Any?
How fast? How many RPM or degrees per second?
And what kind of table? How is it mounted? A table with a ball bearing and a weight of 10 kg can turn more easily than a disc with a bad bearing and a weight of 1 kg.
I want to built a clock so rpm is very low, degrees 360. :stuck_out_tongue_winking_eye:
Some ideas??
Over the last 18 days you have been offered a large number of ideas already.
Did you look into all of them ?
It looks like you haven't even started building the turntable, so what is the point of thinking about the app?
