thobru
November 13, 2014, 9:39am
1
Hi
I want to make a projekt where i can control an antenna signal with my arduino.
so I want to make an signal switch.
but what do i need to this projekt to switch between the signals.
I can't as far as I see use an ordinary relay, because I can't mix power and signal.
Best regards
Thomas
Lavan
November 13, 2014, 10:04am
2
What you mean by controlling the antenna signal? Just switching on and off? what voltage and current you are going to control?
Your question is not clear at all, you need to describe what goal you are trying to achieve rather than the specific problem you are encountering/trying to solve.
Do you want to connect an antenna to two different receivers? What type of antenna/signal are you trying to connect (TV, SAT, FM, ...?).
thobru
November 13, 2014, 10:18am
4
It is a tv signal i want to control.
I would like to be able to turn it on and of.
I'm going to use the arduino with 9v battery, and the arduino will be connectet to the internet, so i can control it from my laptop.
Please let me know if you need more information.
And thank you for your interest in my question.
So you want to interrupt the antenna connection to your TV set with an Arduino?
Are we talking about VHF and UHF signal/antenna?
Hi, if you want to just supply two TV, just use a distribution amp, both TVs will be fed at once then, no need to do any switching.
Tom.....
thobru
November 13, 2014, 1:06pm
7
Yes I want to interrupt the antenna connection to your TV set with an Arduino
as far as I know the digitale signals from the tv Company is about 342 MHz.
så i has to be UHF.
but is this important ?
In my mind it is only the coax cable that is either has contact or not.
But i'm looking forward to hear your idear
thobru
November 13, 2014, 1:07pm
8
But in denmark we also have analog televisiton - so the cable is used both for UHF and VHF signals
Hi, why do you want to switch the TV signal on or off?
Tom........
thobru
November 14, 2014, 12:46pm
10
I'm not sure why - it is a projekt a frend has given me.
Im thinking maybe i can use DIP12-1c90-51L ?
Hi, if I was asked to make this, I would be asking why, where and to what end.
There may be a simpler solution, like switching your TV off.
Tom....
Paul_B
November 15, 2014, 8:00am
12
thobru:
I'm not sure why - it is a projekt a frend has given me. Im thinking maybe i can use DIP12-1c90-51L ?
Well you had better go straight back to your friend and have him explain why he wants to do this and more to the point, exactly what it is he wants to do.
Otherwise he is wasting both our time and yours !
