Hi guys
I was just wondering what you think about my idea here.
Im going to have a bunch of sensors (temperature etc) to transmit code to a base. The whole thing is Arduino based. To save power I'm going to use a Arduino Pro Mini 3.3v clone. The problem is it only outputs 3.3v. The sensors and transmitters needs quite more - around 5v. Therefore I need some kind of boost converter - I'm thinking about using this one. Im not going the read the sensors and transmit the data constantly - maybe only every 5 - 10 minutes. To save power I am thinking about adding a transistor to this setup to cut the power to the boost converter and therefore also the sensors when they are not in use. Im not sure what transistor to get - maybe this NPN?
What do you think about this? Will this work at all? Will the parts be right for this project? Do I need any other parts?
Thanks!
