What does 100.0F mean? (BME280 Library example)
Hello,
Can someone please help me understand the meaning of “100.0F”. Why is it not 100?
 Serial.print(bme.readPressure() / 100.0F);
Serial.println(" hPa");
The code is from Adafruit BME280 library.
 void printValues() {
    Serial.print("Temperature = ");
    Serial.print(bme.readTemperature());
    Serial.println(" *C");
    Serial.print("Pressure = ");
    Serial.print("Approx. Altitude = ");
    Serial.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
    Serial.println(" m");
    Serial.print("Humidity = ");
    Serial.print(bme.readHumidity());
    Serial.println(" %");
100.0 is a floating point value .
100.0F makes damn sure it's a floating point value.
100 is an integer value.
Look up integer and floating point math. There is stuff in the reference above. Weird things happen in code with maths unless you are very specific
F suffix implies float type (single precision).
The default, with a decimal point but without a suffix, would be a double.
Most Arduino platforms (Uno, MEGA etc.) only implement single precision floating point (double is implemented using single precision).
There's also the floating point L suffix for long double, but obviously that's not supported on Uno, Mega, etc. either.
