What does a 15 bit color code look like?
I am using LED strips (6803) and in order for them to come on, you need to specify the LED number and then the LED color.
I got the LED to come on, but I can't figure out the colors without any consistency. Apparently they use a 15 bit color code, but I've googled it and the results I come up with always result in a white LED.
I've used the examples that come with the library, but they don't allow you to manually insert a color, EG solid white. They all fade around a color wheel..
I tried using Serial.write to see what it was sending to the LED, for red I got 99299 but although the colors were close, they were still a bit off. (eg, RED was more faded and orangy.
Thanks!
Usually it just means five bits (0..31) each for red, green and blue
99299
That's a seventeen bit number.
Each colour has a number of bits to control how bright it is. As you have three colours and 15 bits then each colour has 5 bits associated with it.
With 5 bits you can specify 32 different brightnesses. So if you just send the numbers 0 to 31 in turn you should get all the different shades of red.
Now it gets a bit complex because you don't understand about binary bits yet. But the numbers from 32 to 1023 in steps of 32 define all the shades of green. Then the numbers from 1024 to 32768 in steps of 1024 give you all the shades of blue.
You can work out a colour number from these components, Lets say you want 50% red 25% green and 10% blue, convert them first into steps of 32
Red = 16
Green = 8
Blue = 4 ( well 3.2 but we are dealing in integers)
So the 15 bit colour value is equal to:-
16 + ( 32 * 8 ) + ( 1024 * 4 )
or
colour = Red + 32 * Green + 1024 * Blue = 4368
So the result would be 5088 or 122564816?
log2122564816 = ?
I'm a bit thick, but that is around 26... I dont get it :frowning:
Where do you get the 122564816 from?
Corrected final line it is 1024 not 1204, that is my dyslexia kicking in.
I don't know, i was looking at the code I had, and it looked like it might be adding them together as a string of numbers...
R G B
12 256 4816
but now that you edited in the answer, i got it figured out now.
Thanks for your help!
:roll_eyes:
Well, i thought i had it.
If i enter in all the numbers 1-31 i get all the different shades of GREEN
color = ( B * 1024) + (R * 32) + G
appears to be the formula, because when i do
color = ( 31 * 1024) + (0 * 32) + 0
I get full blue
and when i do
color = (0 * 1024) + (31 * 32) + 0
i get full red.
However, when I try to say, for instance get the led strip to put out "yellow" I cant get the code to work, even though i've seen the strip put out the color yellow when it is running the fade program in the example.
The RGB code for a yellow is
R 251
G 232
B 75
I then turned those into percents:
R 44.9%
G 41.6%
B 13.4%
Then I multiplied each number by 31 and got:
R 15
G 13
B 4
then
color = (4 * 1024) + (15 * 32) + 13
color = 4589
but when i put that into the sketch, i get a whitish blue color.... not yellow.
If i use the original formula
color = (B * 1024) + (G * 32) + R
color = (4 * 1024) = (13 * 32) + 15
color = 4527
it's just a little less red and a little less blue ( you gotta be staring at the LED's to tell)
Thanks for the setting me on the right track, guys.
I was able to get the colors working correctly.
I'm using a cheap led strip, so the colors arent quite right. Blue is overly bright so you have to bring it way down to get purples and light blues....
For the yellows, the green overshadows the red so you got to turn the green down.
End result still looks good!
Qdeathstar:
It's a sanity check - a 26 bit number is clearly not a fifteen bit colour value.
Yes that happens with all LEDs the balance is never right. Sometimes you can compensate by having diffrent resistor values in the currents.
Best way is to have three pots and adjust them interactively. Some colours are impossible to get, like brown. You might also like to look at gamma correction that attempts to compensate for the fact that the eye's sensitivity is logarithmic and the LED's output is linear.
Qdeathstar:
That's a 26 bit number, it can't possibly be a "color"
AWOL:
Qdeathstar:
Oh, Thank you for the explanation.
@mike, I would have to put a pot on each LED since the strips are individually controlled?
No you don't put the pot on the LED strip. You connect it to the analogue input, one per pot. Then read the pot value and work out the colour number from the pot values.
To make the range add up divide the pot readings because they are 0 to 1023.
Red = analogRead(A0) >> 5;
Green = analogRead(A1) >> 5;
Blue = analogRead(A2) >> 5;
OH! I get it now
That is a great idea, a lot easier way of finding a color than manually changing the color codes one at a time.
Thanks for the tip, this will make finding colors so much easier.
#include <TimerOne.h>
#include "LPD6803.h"
//Example to control LPD6803-based RGB LED Modules in a strand
// Original code by Bliptronics.com Ben Moyes 2009
//Use this as you wish, but please give credit, or at least buy some of my LEDs!
// Code cleaned up and Object-ified by ladyada, should be a bit easier to use
// Choose which 2 pins you will use for output.
// Can be any valid output pins.
int dataPin = 4;       // 'yellow' wire
int clockPin = 5;      // 'green' wire
// Don't forget to connect 'blue' to ground and 'red' to +5V
long int q = 0;
long int m = 0;
int redpotPin = A2;
int bluepotPin = A3;
int greenpotPin = A4;
int color;
int numpix = 50;
// Timer 1 is also used by the strip to send pixel clocks
// Set the first variable to the NUMBER of pixels. 20 = 20 pixels in a row
LPD6803 strip = LPD6803(numpix, dataPin, clockPin);
  strip.setCPUmax(60);  // start with 50% CPU usage. up this if the strand flickers or is slow
  // Start up the LED counter
  strip.begin();
  // Update the strip, to start they are all 'off'
  strip.show();
  pots();
  Serial.println(color);
  for (q=0; q < numpix; q++){
  strip.setPixelColor(q, color);
  strip.show();   // write all the pixels out
  //Serial.println(q);
  /*if (q > 50) {
    while (m < 50) {
    strip.setPixelColor(m, color);
    delay (100);
    m = m + 1;
    q = 0;
    strip.show();
  m = 0;*/
  //if (q < numpix) {
  //q = q + 1;
  delay (40);
int pots() {
int Red = analogRead(redpotPin) >> 5;
int Green = analogRead(greenpotPin) >> 5;
int Blue = analogRead(bluepotPin) >> 5;
color = Blue*1024 + Red*32 + Green;
//Serial.println(color);
//return color;
Do you have to debounce the potentiometers? Because, if i don't have a delay of at least 40, the lights toward the end of the strip flicker?
long int q = 0;
long int m = 0;
int redpotPin = A2;
int color;
LPD6803 strip = LPD6803(50, dataPin, clockPin);
  strip.begin();
  strip.show();
  pots();
  if (q > 50) {
    while (m < 50) {
    delay (100);
    m = m + 1;
    q = 0;
    strip.show();
  m = 0;
  q = q + 1;
  delay (100);
int pots() {
//return color;
Also, what if i wanted to make blue's upper limit less than the upper limit of red and green?
And can you explain how
turns the 1023 value into 31? <magic.
I know it has something to do with shifting bytes.....
1010101 being turned into 10 but i still don't understand how it turns into 31...
1023 = 210 - 1.
31 = 25 - 1
">> x" divides by 2x, so 1023 / 32 = 31.
