What does a variable in between % signs means? %VARIABLE%
Hi Everyone,
I’m having a hard time searching on what a variable in betwween percent signs means. The code is listed here and he briefly explains this is a placeholder. But this seems to be delivered as a string to the webbrowser portion. Is this correct? If so how do I go about converting it directly from a numerical variable (byte, int)?
Code listed here or copy here:
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/esp32-esp8266-thermostat-web-server/
  Permission is hereby granted, free of charge, to any person obtaining a copy
  of this software and associated documentation files.
  The above copyright notice and this permission notice shall be included in all
  copies or substantial portions of the Software.
#ifdef ESP32
  #include <WiFi.h>
  #include <AsyncTCP.h>
#else
  #include <ESP8266WiFi.h>
  #include <ESPAsyncTCP.h>
#endif
#include <ESPAsyncWebServer.h>
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
// REPLACE WITH YOUR NETWORK CREDENTIALS
const char* ssid = "REPLACE_WITH_YOUR_SSID";
const char* password = "REPLACE_WITH_YOUR_PASSWORD";
// Default Threshold Temperature Value
String inputMessage = "25.0";
String lastTemperature;
String enableArmChecked = "checked";
String inputMessage2 = "true";
// HTML web page to handle 2 input fields (threshold_input, enable_arm_input)
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html><head>
  <title>Temperature Threshold Output Control</title>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  </head><body>
  <h2>DS18B20 Temperature</h2>
  <h3>%TEMPERATURE% &deg;C</h3>
  <h2>ESP Arm Trigger</h2>
  <form action="/get">
    Temperature Threshold <input type="number" step="0.1" name="threshold_input" value="%THRESHOLD%" required>
    Arm Trigger <input type="checkbox" name="enable_arm_input" value="true" %ENABLE_ARM_INPUT%>
    <input type="submit" value="Submit">
  </form>
</body></html>)rawliteral";
void notFound(AsyncWebServerRequest *request) {
  request->send(404, "text/plain", "Not found");
AsyncWebServer server(80);
// Replaces placeholder with DS18B20 values
String processor(const String& var){
  //Serial.println(var);
  if(var == "TEMPERATURE"){
    return lastTemperature;
  else if(var == "THRESHOLD"){
    return inputMessage;
  else if(var == "ENABLE_ARM_INPUT"){
    return enableArmChecked;
  return String();
// Flag variable to keep track if triggers was activated or not
bool triggerActive = false;
const char* PARAM_INPUT_1 = "threshold_input";
const char* PARAM_INPUT_2 = "enable_arm_input";
// Interval between sensor readings. Learn more about ESP32 timers: https://RandomNerdTutorials.com/esp32-pir-motion-sensor-interrupts-timers/
unsigned long previousMillis = 0;
const long interval = 5000;
// GPIO where the output is connected to
const int output = 2;
// GPIO where the DS18B20 is connected to
const int oneWireBus = 4;
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(oneWireBus);
// Pass our oneWire reference to Dallas Temperature sensor
DallasTemperature sensors(&oneWire);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  if (WiFi.waitForConnectResult() != WL_CONNECTED) {
    Serial.println("WiFi Failed!");
    return;
  Serial.print("ESP IP Address: http://");
  pinMode(output, OUTPUT);
  digitalWrite(output, LOW);
  // Start the DS18B20 sensor
  sensors.begin();
  // Send web page to client
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/html", index_html, processor);
  // Receive an HTTP GET request at <ESP_IP>/get?threshold_input=<inputMessage>&enable_arm_input=<inputMessage2>
  server.on("/get", HTTP_GET, [] (AsyncWebServerRequest *request) {
    // GET threshold_input value on <ESP_IP>/get?threshold_input=<inputMessage>
    if (request->hasParam(PARAM_INPUT_1)) {
      inputMessage = request->getParam(PARAM_INPUT_1)->value();
      // GET enable_arm_input value on <ESP_IP>/get?enable_arm_input=<inputMessage2>
      if (request->hasParam(PARAM_INPUT_2)) {
        inputMessage2 = request->getParam(PARAM_INPUT_2)->value();
      else {
        inputMessage2 = "false";
        enableArmChecked = "";
    Serial.println(inputMessage);
    Serial.println(inputMessage2);
    request->send(200, "text/html", "HTTP GET request sent to your ESP.
<a href=\"/\">Return to Home Page</a>");
  server.onNotFound(notFound);
  server.begin();
  if (currentMillis - previousMillis >= interval) {
    sensors.requestTemperatures();
    // Temperature in Celsius degrees
    float temperature = sensors.getTempCByIndex(0);
    Serial.print(temperature);
    Serial.println(" *C");
    // Temperature in Fahrenheit degrees
    /*float temperature = sensors.getTempFByIndex(0);
    Serial.println(" *F");*/
    lastTemperature = String(temperature);
    // Check if temperature is above threshold and if it needs to trigger output
    if(temperature > inputMessage.toFloat() && inputMessage2 == "true" && !triggerActive){
      String message = String("Temperature above threshold. Current temperature: ") +
                            String(temperature) + String("C");
      Serial.println(message);
      triggerActive = true;
      digitalWrite(output, HIGH);
    // Check if temperature is below threshold and if it needs to trigger output
    else if((temperature < inputMessage.toFloat()) && inputMessage2 == "true" && triggerActive) {
      String message = String("Temperature below threshold. Current temperature: ") +
                            String(temperature) + String(" C");
I’m looking at the
%TEMPERATURE%
and this piece of code:
  return String();
Many thanks.
I haven't read or tried it, but this tutorial seems to explain what you're after: https://techtutorialsx.com/2018/07/23/esp32-arduino-http-server-template-processing-with-multiple-placeholders/
Pieter
PieterP: I haven't read or tried it, but this tutorial seems to explain what you're after: https://techtutorialsx.com/2018/07/23/esp32-arduino-http-server-template-processing-with-multiple-placeholders/
Pieter
Lovelly, Thanks! So the variable is a string and that loop just takes the string into the 'placeholder'. So I guess I need to convert my int to a string and let the code do it's thing after :-)
When the html code is a static webpage then it is a common way to have something in the html code (a "placeholder"), where the Arduino or ESP can inject realtime data.
A simple way is A, _B, _C, and so on. Then 26 variables are possible. With a longer name, it can be _DOOR, LIGHT, TEMPERATURE. The #TEMPERATURE# is not a good choice, because the # is used in html code. The {TEMPERATURE} is possible, or ^TEMPERATURE^. They choose the percent sign %TEMPERATURE%. Perhaps you should be careful when using the percent sign for other things.
It seems to work together with the String object, so you should convert the integer into a String object.
Koepel: ... They choose the percent sign %TEMPERATURE%. Perhaps you should be careful when using the percent sign for other things.
This is interesting, because I actually wanted to print a percent (%) on the webpage as text, but it breaks the code, so I have to use 78pc or 78percent. Could this be the reason why? Is there a way to change it? Thanks!
