I am trying to decipher some example code and the following line appears in a local .h file:
void M5PaperTouchAreas::loop() {
What is the purpose of the "::" generally and specifically what do they do in the name of a function as here?
The "::" (double colon) is known as Scope Resolution Operator. You can try to find the meaning/purpose of this operator from the following sketch which contains class-based codes to blink the on-board LED (L) of UNO at 1-sec interval?
class DigitalIo //Class Name (DigitalIo); do Capitalize the first letter for Class Name
private:
int ledPin; //variable can only be accessed by the functions under public: specifier
public:
DigitalIo(int DPin);//: ledPin(powerpin) {} //inline constructor to initilize ledPin
void ioDir(); //member function
void ledOn();
void ledOff();
DigitalIo led(13); //led is called object of type DigitalIO
led.ioDir(); //setting up the direction of IO line(13) as output
led.ledOn();
led.ledOff();
void DigitalIo::ioDir() //member function definition; :: (double colon) is calld scope resolution operator
pinMode(ledPin, OUTPUT);
void DigitalIo::ledOn()
digitalWrite(ledPin, HIGH);
void DigitalIo::ledOff()
digitalWrite(ledPin, LOW);
DigitalIo::DigitalIo(int x)
ledPin = x;
a class is normally defined in a ,h file which is included in other files using that class. the class definition does not need to define the functions of that class, i can just provide prototypes.
so the functions need to be defined in another .cpp files and need to be associated with the class they are in and are defined as class::function-name
