I have just ordered a couple of these to replace a two-mechanical relays, board that are proving to be unreliable for any length of time.
But now, not sure if the SSR are a drop in replacement or not. Farther down that page is says,
3, the input power supply: 5V DC (160MA)
4, the input control signal voltage:
(the state of the 0-2.5V low level relay OFF)
(the state of the 3-5V high level relay ON)
5, the blue KF301 terminal is connected to the line of control more convenient.
Module interface:
Input part:
DC+: connect the power supply positive (press the relay voltage power supply)
DC-: the cathode of a power supply
CH: relay module signal trigger end (high level trigger effective)
Can I still drive these SSR for small pumps (0.7A and 0.9A) directly from the Nano Data-Pins?
@terryking228
This seems wrong for a 2-channel board: "5VDC / 160mA (all channel ON)."
Probably taken from an 8-relay board, so could be "20mA per relay".
I doubt it's even that much.
Leo..
With my meter I am unable to read any current at all. I jumpered across from the the 5vdc to the CH-1- and the red LED comes on for each SSR, but not enough current to measure. I am guessing it is not going to eat the Nano then.
As soon as the thing stops running, I will install this board in place of the mechanical relays. All looks hopeful.
