I know the usual tricks to fix this; these will not work because I am hacking up an installation with locally present tools and compiler so I can develop these things on one system without fucking them up system-wide by using board manager installation.
This is the error to which I refer:
___REMOVE___/bin/avrdude -CC:\Users\Pete\Documents\Arduino\hardware\megaTinyCore\megaavr/avrdude.conf -v -pattiny3216 -cjtag2updi -PCOM3 -Uflash:w:C:\Users\Pete\AppData\Local\Temp\arduino_build_253941/ws2812test.ino.hex:i
java.io.IOException: Cannot run program "___REMOVE___/bin/avrdude": CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:26)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:129)
at cc.arduino.packages.uploaders.SerialUploader.runCommand(SerialUploader.java:383)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingProgrammer(SerialUploader.java:315)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:90)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
at processing.app.SketchController.upload(SketchController.java:732)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$UploadHandler.run(Editor.java:2055)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.<init>(ProcessImpl.java:386)
at java.lang.ProcessImpl.start(ProcessImpl.java:137)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 10 more
An error occurred while uploading the sketch
Unfortunately, in very unpredictable circumstances, (I have multiple installations where I thought I did everything the same, but one version works, and the other version gives the REMOVED error, and I don't know how to make it not do that. The "reinstall everything" strategy here is no good, because if I do that, the problem just comes back when I put my mods in)
