thdfx
May 14, 2021, 9:08am
#1
This code is an example code for a water level sensor and was given to me without any attached explanation of how it works. can anyone please explain?
int adc_id = 0;
int HistoryValue = 0;
char printBuffer[128];
int value = analogRead(adc_id);
if(((HistoryValue>=value) && ((HistoryValue - value) > 10)) || ((HistoryValue<value) && ((value - HistoryValue) > 10)))
sprintf(printBuffer,"ADC%d level is %d\n",adc_id, value);
Serial.print(printBuffer);
HistoryValue = value;
if the previous value is greater than or equal to the value just read
AND
the difference between the previous value and the value just read is greater than 10
OR
the previous value is not zero
AND
the value just read is at least 10 greater than the previous value
then do something
MarkT
May 14, 2021, 11:05am
#3
Its using hysteresis to avoid being affected by small changes or noise in the signal. It would be much clearer and simpler if written as:
if (abs (value - HistoryValue) > 10) // if more than 10 different from last recorded reading
HistoryValue = value ;
system
Closed
September 11, 2021, 11:06am
#4
