What does thus section of code mean
This is an outsourced bit of code that will program a lilypad Arduino jacket. I am unsure of what this section of code means. Does anyone out there understand this? I am a beginner wanting to learn!
First section of code is the area I am stuck with. Rest of the code below for context if that helps anyone
void RightTurn()
digitalWrite(rightSignal, HIGH);
delay(1000); // wait for 1 second
if (digitalRead(rightSwitch) == LOW)
while (digitalRead(rightSwitch) == LOW);
digitalWrite(rightSignal, LOW); // turn the right signal off
return;
delay(1000); // wait for one second
return;
int leftSwitch = 6; // my left button is attached to petal 6
int rightSwitch = 12; // my right button is attached to petal 12
int rightLow = 4; // the - side of my right button is attached to petal 4
int leftSignal = 8; // my left turn signal is attached to petal 8
int rightSignal = 11; // my right turn signal is attached to petal 11
int signalLow = 10; // the - sides of my signals are attached to petal 10
int boardLED = 13; // the LED on the Lilypad
void setup() // run once, when the sketch starts
pinMode(boardLED, OUTPUT); // sets the boardLED to be an output
pinMode(leftSignal, OUTPUT); // sets the leftSignal petal to be an output
pinMode(rightSignal, OUTPUT); // sets the rightSignal petal to be an output
pinMode(signalLow, OUTPUT); // sets the signalLow - petal to be an output
pinMode(rightLow, OUTPUT); // sets the signal rightlLow petal to be an output
pinMode(leftSwitch, INPUT); // sets leftSwitch to input pin
digitalWrite(leftSwitch, HIGH); // sets leftSwitch on
pinMode(rightSwitch, INPUT); // sets rightSwitch to input pin
digitalWrite(rightSwitch, HIGH); // sets rightSwitch on
digitalWrite(boardLED, HIGH); // sets boardLED on
digitalWrite(signalLow, LOW); // sets the signalLow petal to Low (-)
digitalWrite(rightLow, LOW); // sets the right button off
void loop() // run over and over again
checkLeft(); // checkleft state
checkRight(); // checkRight state
void checkLeft() // code to establish boardLED saftey light
if (digitalRead(leftSwitch) == LOW) // left switch not pressed
digitalWrite(boardLED, LOW);
while (digitalRead(leftSwitch) == LOW) // boardLED off
if (digitalRead(rightSwitch) == LOW) // right switch not pressed
while (digitalRead(rightSwitch) == LOW | digitalRead(leftSwitch) == LOW);
digitalWrite(boardLED, HIGH); // no buttons pressed boardLED on
return;
leftTurn();
void checkRight() //code to establish boardLED saftey light
while (digitalRead(rightSwitch) == LOW) // boardLED off
while (digitalRead(leftSwitch) == LOW | digitalRead(rightSwitch) == LOW);
return;
void leftTurn()
digitalWrite(leftSignal, HIGH); // LED pannel on
if (digitalRead(leftSwitch) == LOW) // if button not pressed LED off
while (digitalRead(leftSwitch) == LOW);
digitalWrite(leftSignal, LOW); // LED off no button press
return;
digitalWrite(leftSignal, LOW); // turns off LED pannel
if (digitalRead(leftSwitch) == LOW) // checks to see if pushbutton is pressed
while (digitalRead(leftSwitch) == LOW); // lights stay
return;
Hi
Well the answer is, to my eyes that this is badly written code
It also seems that the actual thing that it is trying to do is not all that complicated
I would suggest that you draw out a logic table of what you want the controls to do under all conditions. ie
Take an input pin (Right Switch). It has two states, ON, OFF and two transitions On to OFF and OFF to ON
Usually transitions are not important considerations so ON and OFF is all you need
Then look at the condition of the switch, does it go on as a pulse or is it held
The first few lines of the code seem to give an idea that for a right turn the right signal is instantly turned on, but after a second delay the low state of the switch is considered and a low signal output is given for as long as the Right Switch is low.. A bit dumb really. You can continuously look at the state in void() and at each state issue a command to an output.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
These warning indicate that you should be using "||" (logical OR) here and not "|" (bitwise OR) in these two statements.
/Users/john/Documents/Arduino/sketch_oct12a/sketch_oct12a.ino: In function 'void checkLeft()':
/Users/john/Documents/Arduino/sketch_oct12a/sketch_oct12a.ino:48:41: warning: suggest parentheses around comparison in operand of '|' [-Wparentheses]
/Users/john/Documents/Arduino/sketch_oct12a/sketch_oct12a.ino: In function 'void checkRight()':
/Users/john/Documents/Arduino/sketch_oct12a/sketch_oct12a.ino:66:40: warning: suggest parentheses around comparison in operand of '|' [-Wparentheses]
