What does TIMSK1 = bit (TOIE1); mean ??
I’m studying the tutorial by Nick Gammon
http://www.gammon.com.au/timers
I’ve pretty much managed to find out what all the different C commands mean except for this one:
Could anyone explain that one to me.
Cheers,
Keith.
That's covered in the datasheet - he's setting the TOIE1 bit in the TIMSK1 register. From memory, that enables the timer 1 overflow interrupt.
(Timer Overflow Interrupt Enable 1, Timer Interrupt MaSK 1)
See datasheet for the details
beefy23: managed to find out what all the different C commands mean
Most of them are (more or less) simple assignment, not special 'C commands'.
Many of the acronyms represent registers that can be used like normal C-variables, they are just predefined in a special way to enshure the correct access pattern.
Others represent bits, bit-positions, and macros moving bits to the right place, combining them, ...
Its not an extension of the C++ language.
Thanks very much.
I have started reading the datasheet but wanted to understand what the instructions mean first.
I know what the “TIMSK1” and “TOIE1” are. I suppose I was asking what is the instruction doing. So the
“= bit” means set to 1
Or put another way, the whole instruction means “in register TIMSK1, set bit TOIE1 to 1”.
The instructions I’ve commonly seen to do the same thing are like this:
TIMSK1 |= (1 << TOIE1);
so I was wondering if TIMSK1 = bit (TOIE1); had a different meaning. Guess it’s just different ways to do the same thing.
That actually has me wondering about using this instruction to CLEAR a bit. Would it be NOT bit:
TIMSK1 = !bit (TOIE1);
Keith.
And it with a mask representing the bitwise complement.
TIMSK1 &= ~bit (TOIE1);
And setting the bit would better be (this does not disturb the other bits in the register)
TIMSK1 |= bit (TOIE1);
See: https://www.arduino.cc/en/Reference/Bit
The boolean not ! and the bitwise not ~ are different operators.
Ah great, thank you all very much.
Keith.
beefy23: so I was wondering if TIMSK1 = bit (TOIE1); had a different meaning. Guess it's just different ways to do the same thing.
I think it's just a bit of hand-holding for people that might be startled by the C bit operators.
