What drive for an Electromagnetic Type Push/Pull motor?
Hello,
I would like to push a piston of a small syringe (1 mL or less) using ARDUINO. I have found this motor
https://www.amazon.de/gp/product/B01EJ800QW/ref=ask_ql_qh_dp_hzaSo my questions are:
  • what driver can I use for this?
  • 2.1 kg seems a bit too much force for a 1 mL syringe -- is there a smaller type?
Thank you
its a solenoid not motor. you have to check how much force is to be applied on the syringe
The amount of force depends upon the mechanism between the SOLENOID and the syringe.
Hello,
I need a motor to push/pull a piston of a 1 mL syringe. I have found this motor:
What motor drive can I use for it on arduino?
You need to ask the vendor of the solenoid what the current draw is.
That is not a motor, that is a linear actuator. It is designed to be all the way in or out from the spring, and all the way the opposite direction when energized. Is that what you need?
All that needs is a transistor to energize it. Logic Level N-channel MOSFET would be good, such as
https://www.digikey.com/products/en?keywords=aoi514
RDS(ON) (at VGS = 4.5V) < 11.9mΩ
Here's the kind of info you're looking for in the part you select:
Or are you after a motor that can move a plunger in and out in a more controlled manner?
Maybe a small version of something like this
@Gigiux, please do not cross-post. Threads merged.
I did not know about the difference between motors and actuators, sorry. Anyway, I am looking for an all-in/all-out actuator, but with the smallest dimensions and as cheap as possible (if there are alternatives to the A14092600ux0438, please let me know). It is not reported what the force produced is. I'll try the transistor, thank you. Is there a scheme on how to connect an actuator?
The transistor @CrossRoads suggested is out of stock on Alpha & Omega. I found this substitute on Amazon https://www.amazon.de/Semiconductor-MOSFET-N-CH-SOIC-NTMS4920NR2G/dp/B07R5C1HML/ref=sr_1_1?dchild=1&keywords=MOSFET+N-CH+30V+17A&qid=1593066205&sr=8-1 which has the same specifics (N-CH, 30V, 17A); otherwise, there is this: https://www.amazon.de/20PCS-IRFZ24N-MOSFET-IRFZ24-Transistor/dp/B082LW4F5B/ref=sr_1_fkmr2_1?dchild=1&keywords=MOSFET+N-CH+30V+17A+TO251A&qid=1593065329&sr=8-1-fkmr2 but has 55V. Would they be good?
PS: apologies for the cross-post: I thought the first post did not go out...
A solenoid is no use for a syringe - it will either be too weak and nothing happens, or it will empty the syringe
in one go completely uncontrolled.
You need a linear actuator. An actuator is a motor and lead-screw mechanism. It will not be very cheap, this
is precision miniature engineering. The only way to be cheap is make the mechanism yourself, which requires
machine-shop facilities really. Standard studding (aka all-thread) is fine for making leadscrews if you are happy
for a little backlash.
Lots of people have done this, go and search around for inspiration.
