So I am trying to solder a wire to a PSB board.
Here is a image of a different person doing it: http://www.instructables.com/files/deriv/F6G/IBR1/GREPYEFM/F6GIBR1GREPYEFM.LARGE.jpg
But when I try to do it the solder does not stick to the PCB.
What flux would be best for this?
I am fairly new to this and if you could possibly send me a link to where I can buy the one I need, that would help
So basically I am asking is, what flux would be best for what I am trying to do?
Are all fluxes the same? Are some better than others?
I am new to using flux, and is it also possible I could pick it up from a store like radio shack?
Also if the liquid flux is good for this project, will it be good for other things? Like connecting to wires together?
radio shack has some paste flux and its not as easy to handle as a liquid flux pen, and is messy as all get out, but is usually more agressive than the liquid
typically the flux in your solder should be enough, here are some tips
clean the pads, use a nylon scowering pad (you know those green ones) to clean off oxidation, that is probably most of your problem
tin your wires, tin your pads and just melt the two together
if you get liquid get it in a pen, they have them on digikey and mouser, its much easier to deal with when its in a felt tip marker
I use the kester stuff, its good but could be just a tad bit stronger
You should not be sanding anything. With leaded solder, the rosin flux in the wire should be enough. If you are using lead free solder, then you should also get a no-clean flux meant for it. The No Clean Kester flux pen is just what you need.
Do NOT use paste flux or plumbing flux or acid flux. I try to stay away from Radio Shack solder and fluxes, they tend to be rather strong.
That black thing, as others have said, is covering the chip. That is called COB or Chip On Board. Rather than mount the chip inside an IC package, it is stuck right on the board and tiny wires are connected to the PCB traces. If you sanded that off, it is ruined.
If it works, it works. Why were you sanding the board in the first place? For corroded PCB traces, I use nothing stronger than a pink eraser. And that's only if I'm having problems.
A slightly belated response here, but I don't rely on flux to clean corroded or oxidized leads or pads, and wouldn't ever think of using sandpaper or steel wool. Rather I scrape with an Exacto knife till things are shiny and new. I "always" do this to the feet on smt chips, and the legs on TO-220 parts, as a matter of standard practice.
It's for smt chip legs [corroded parts leads, and TO-220 component legs], not copper traces. I meant to say "parts", not "pads".
Try it and see. Don't slice. Turn the chip over on its back - dead bug style. Hold the blade at a flatish angle, with the sharp side of the blade away from the direction of travel. And lightly scrape. Anyone who can use diagonal pliers to strip insulation off of wire can easily do the deed.
I've been doing this routinely for about 15-years now, ever since I had some trouble with some parts with oxidized leads, and it works 100% better than any flux. The solder always flows right.
