I'm looking at the Feedback 360 Degree - High Speed Continuous Rotation Servo from AdaFruit.
What I don't understand is how the feedback of the current position is "formatted". The details say "PWM positional feedback across entire angular range" but does that get "averaged" in some way into a DC voltage...?
Or do I need to add a low pass filter to do the averaging myself?
Or do I need my software to measure the pulse width?
Or have I misunderstood something?
You have to measure the pulse width using Arduino's pulseIn() function.
MrY
July 13, 2024, 4:17pm
3
Here is a link to a library that may provide the answer to your question.
The Adafruit video mentions that the feedback is from an AS5600 sensor. See the data sheet for the details on the PWM output (page 27)
https://www.mouser.com/datasheet/2/588/AS5600_DS000365_5_00-1877365.pdf
From the servo data sheet:
But do I need a libary, can't I just use pulseIn() ? Genuine question, I have no experience with continuous servos...
Thanks, so I use pulseIn() with the formula you've shown me? Have I understood?
Finally got round to following your advice an I've implemented this for the Parallax 360 feedback servo, seems to work:
static const double kFeedbackFreq = 910.0 ;
static const double kFeedbackCycleTimeSeconds = 1.0/kFeedbackFreq ;
static const double kFeedbackCycleTimeMicroseconds = kFeedbackCycleTimeSeconds*1000000 ;
int Read_Servo_Angle()
// See how high the pulse is in microseconds
int iServoPulseFeedbackMicros = pulseIn (ikHoursServoFeedbackPin,HIGH) ;
// these also depend on your servo...
const double kDutyCycleMin = 0.027 ;
const double kDutyCycleMax = 0.971 ;
// Get a fraction from 0.027 to 0.971
double DutyCycle1 = iServoPulseFeedbackMicros/kFeedbackCycleTimeMicroseconds ;
// Convert to a fraction from 0.0 to 1.0
double DutyCycle2 = (DutyCycle1-kDutyCycleMin)/(kDutyCycleMax - kDutyCycleMin) ;
Serial.print ("DC1=") ; Serial.print (DutyCycle1) ;
Serial.print (", DC2=") ; Serial.println (DutyCycle2) ;
// Convert to an angle...
const double kDegsAngle = 180.0 - (DutyCycle2*360.0) ;
return int(kDegsAngle+0.5) ;
