im going to split the module output(both digital and analog(5V) ) to 2 or 3 arduino instead of using serial port communication, so what happened to the output value?Thanks!
I am assuming you have a module that you want to connect to the inputs on 2-3 Arduinos.
The digital inputs will likely have no issue. The tolerance on the inputs is several tenths of a volt.
The analog input may not have an issue, but you will be connecting 2-3 ADCs in parallel. How far apart will the arduinos be (ie., how much wire from the module to each arduino)? The tolerance for receiving the same reading is 4.9mV; much tighter than the digital pin. So if there is an issue, this will likely be the cause.
You should not hurt anything if you try. I would connect the module to one arduino and record the readings, then connect the second and check the readings for both, then repeat for connecting the he third arduino.
adwsystems:
I am assuming you have a module that you want to connect to the inputs on 2-3 Arduinos.The digital inputs will likely have no issue. The tolerance on the inputs is several tenths of a volt.
thanks for answering !I'll try to solder the wire up and see if there is a problem!
Please report back with success or failure.
