Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\Aaron Jimmy\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\Aaron Jimmy\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM8" -b115200 -D "-Uflash:w:C:\Users\Aaron Jimmy\AppData\Local\Temp\arduino\sketches\9861A8E4B88CB69B95BA7F943C33752B/sketch_jan2a.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Aaron Jimmy\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM8
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe2
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
my arduino is doing this when i touched the pin 13 and it automattically turned off and its start doin this, what happened,
my arduiino is uno r3
