Sorry I missed this somehow.
Just connected mine to double check.
A decent test is the "blink without delay" sketch HERE.
Remembered that the two LEDs nearest the charge connector will turn OFF when connected to a battery !
If you load the sketch above and charge the battery then disconnect your USB you should only see the onboard LED blink. Its part of the power saving feature.
