Why change???
I can only post ONE emoji at a time and the panel closes, why?
Tom...
PS. Lucky I saved my emoiji text.
PPS. Found it but I had to scroll down I don't know how many pages..grrrrrrr..
PPPS. If it ain't broke don't fix it..
The metadata for the :australia: emoji doesn't contain the keyword flag, so this is why you don't see that emoji in the search results for the flag keyword. The source of the additional search keywords come from Unicode:
However, there is no unicode character for the Australian flag, so no annotation data is available to provide additional search keywords for this emoji . The :australia: emoji comes from Twemoji, and I don't believe that Twemoji provides any annotation data, so the emoji will only appear in the search results for the emoji markup itself.
Are you sure used to appear in the results for a flag keyword search?
You still haven't explained what is broken. The emoji is still there.
This is the data used by the emoji picker and autocomplete keyword search:
It hasn't been changed for two years. The forum has been updated many times since then. So I don't see any reason to believe that the search behavior changed recently.
I made a significant effort to respond to your post. If you won't make the effort to help me understand what the problem is then there is nothing more I can do.
That's the point , nothing was broken, but it has been changed, the layout is different.
Why can I not select 4 emojis one after the other to put in my post and the panel stays open?
Now the emoji panel CLOSES after each emoji is selected.
So to put more than one emoji in a post, you have to select the emoji icon for each emoji.
Note the emoji icon has changed too.
Unless the layout change caused a regression, I don't see that this is a problem.
Thanks for the clarification. I confirm that the picker had the behavior you describe at previous version c1a4699 of the Discourse forum framework (the test instance of the forum happens to have that version of Discourse):
The complete list of changes between version c1a4699 and the version d144826 of Discourse that is currently in use by Arduino Forum:
This looks like the likely cause of the changed design and behavior:
I verified that doesn't show up in the search results for flag in version c1a4699 of Discourse either, so I'm now confident there hasn't been a regression in that respect.
Sorry, I don't want to know what code was changed, I want to know WHY?
The one pick then close, I would regard as a bug, what was wrong with the way it worked before.
Why for a start go to the trouble of changing the icon, one emoji face, now three much smaller emoji, in fact I thought it was a bit of dirt on my screen.
Did the individual(s) who changed the code, actually fully test it.
Did they check how it looks on a phone , or like me a 15inch LCD, not a 30inch like they probably have?
