So was going great guns last night after work, and decided it was time to up the ante.
I want my usb bought on my Arduino 2560 to be a usb midi port, so I will flash the u8. Then to program it I will use my AVR ISIP mkII. and power it from an external power supply.
Firstly, is that a bad move - to have the usb connected and an external power supply? If I convert the u8 chip to midi will it still power the arduino?
Secondly, and the real question. I plugged the external power supply in and realised it was center negative/positive - whichever way round is the wrong was around for arduino. I swapped it around and the power light came on, and the led 13 came on. When I hit the reset button, the led 13 goes out then comes back on again. This tells me (I think) that the bootloader is still present?
When I look in device manager I see arduino on com 34. However in arduino IDE it does not appear under as a serial port. When I try to program it using avr isp mk II, it get AVR Dude complaining that it couldn't find USB 'usb'.
So the question is have I fried something? Can i resurrect it? Should I start by trying to burn the bootloader in AVR Studio? Is there any confirmation as to whether anything is bust?
Cheers guys
If you are using windows, can you go to device manager and change it to a com less than 10? That might help.
Yeah, I'll do that when Im back from work, just seems a little too much to be a coiincidence that when this all happened I cant connect.
Does the fact that it appears in the device manager give you/me hope that I might not have fried something? (he says hopefully...)
See this discussion about using USB and External Power at the same time:
http://arduino.cc/forum/index.php/topic,82046.0.html
That tells you that the USB to serial chip is probably working.
So I've bricked the usb port. When I get home I will try once to flash the atmega8u2 with the firmware again, and then write to it. Otherwise I can try I suppose to program it with my isp mk ii and then with my serial to usb cable get info back to the terminal for current development but eventually I will need usb back...
I wasnt quite sure though from reading that thread - if it appears as Arduino in device manager does that tell us anything?
Saved it!
Using avr studio I re burnt the firmware to the mega8u and everything works perfectly!
