Having trouble with this script.
Can adjust menu items 1 to 3 fine (Small debounce issue)
When selecting menu4 the screen and arduino seem to freeze. No data is updated and i the rotary encoder becomes unresponsive.
Menu4 should. Once selected,
If (halleffect triggers)
-1 from Menu1 value until it reaches 0
Update screen at each -1
I've spent about 30mins looking over all parts of menu4 but i can't see what i've done to make it do what it is doing.
Any help appreciated.
//20x4 LCD
#include <LiquidCrystal_I2C.h> //SDA = A4, SCL = A5 Arduino https://www.arduino.cc/reference/en/libraries/liquidcrystal-i2c/
LiquidCrystal_I2C lcd(0x27, 20, 4);
int menuCounter = 0; //counts the clicks of the rotary encoder between menu items (0-3 in this case)
int menu1_Value = 0; //value within menu 1
int menu2_Value = 0; //value within menu 2
int menu2_StoredValue = 0; // STORED VALUE FOR COMPARRISSON
int menu3_Value = 0; //value within menu 3
int menu3_StoredValue = 0; // STORED VALUE FOR COMPARRISSON
int menu4_Value = 0; //value within menu 4
bool menu1_selected = false; //enable/disable to change the value of menu item
bool menu2_selected = false;
bool menu3_selected = false;
bool menu4_selected = false;
//Note: if a menu is selected ">" becomes "X".
//Defining pins
//Arduino interrupt pins: 2, 3.
const int RotaryCLK = 2; //CLK pin on the rotary encoder
const int RotaryDT = 4; //DT pin on the rotary encoder
const int PushButton = 3; //Button to enter/exit menu
//Statuses for the rotary encoder
int CLKNow;
int CLKPrevious;
int DTNow;
int DTPrevious;
bool refreshLCD = true; //refreshes values
bool refreshSelection = false; //refreshes selection (> / X)
// HE Sensor code
// HE Sensor code
#define DETECT 5 // pin 5 for sensor (D5)
#define ACTION 8 // pin 8 for action to do someting (A1)
// HE Sensor code
// HE Sensor code
const int redRELAY_PIN = 11; //
const int greyRELAY_PIN = 12; //
pinMode(2, INPUT_PULLUP); //RotaryCLK
pinMode(4, INPUT_PULLUP); //RotaryDT
pinMode(3, INPUT_PULLUP); //Button
lcd.init();//lcd.begin(); /// not known in library lcd.init();/// // initialize the lcd
lcd.backlight();
lcd.setCursor(0, 0); //Defining positon to write from first row, first column .
lcd.print("Menu demo");
lcd.setCursor(0, 1); //Second row, first column
lcd.print("Rotary encoder");
lcd.setCursor(0, 2); //Second row, first column
lcd.print("Improved version");
delay(50); //wait 1 sec
lcd.clear(); //clear the whole LCD
printLCD(); //print the static parts on the screen
//Store states of the rotary encoder
CLKPrevious = digitalRead(RotaryCLK);
DTPrevious = digitalRead(RotaryDT);
attachInterrupt(digitalPinToInterrupt(RotaryCLK), rotate, CHANGE); //CLK pin is an interrupt pin
attachInterrupt(digitalPinToInterrupt(PushButton), pushButton, FALLING); //PushButton pin is an interrupt pin
// HE Sensor code
// HE Sensor code
/// Serial.println("Hall Module Test"); ///TESTING///
pinMode(DETECT, INPUT);//define detect input pin
pinMode(ACTION, OUTPUT);//define ACTION output pin
// HE Sensor code
// HE Sensor code
pinMode(redRELAY_PIN, OUTPUT);
pinMode(greyRELAY_PIN, OUTPUT);
digitalWrite(greyRELAY_PIN, LOW);//RepeatNotColourChanger
digitalWrite(redRELAY_PIN, LOW);
if (refreshLCD == true) //If we are allowed to update the LCD ...
updateLCD(); // ... we update the LCD ...
//... also, if one of the menus are already selected...
if (menu1_selected == true || menu2_selected == true || menu3_selected == true || menu4_selected == true)
// do nothing
updateCursorPosition(); //update the position
refreshLCD = false; //reset the variable - wait for a new trigger
if (refreshSelection == true) //if the selection is changed
updateSelection(); //update the selection on the LCD
refreshSelection = false; // reset the variable - wait for a new trigger
void rotate()
//-----MENU1--------------------------------------------------------------
if (menu1_selected == true)
CLKNow = digitalRead(RotaryCLK); //Read the state of the CLK pin
// If last and current state of CLK are different, then a pulse occurred
if (CLKNow != CLKPrevious && CLKNow == 1)
// If the DT state is different than the CLK state then
// the encoder is rotating in A direction, so we increase
if (digitalRead(RotaryDT) != CLKNow)
if (menu1_Value < 9999) //we do not go above 9999
menu1_Value++;
menu1_Value = 0;
if (menu1_Value < 1) //we do not go below 0
menu1_Value = 9999;
// Encoder is rotating B direction so decrease
menu1_Value--;
CLKPrevious = CLKNow; // Store last CLK state
//---MENU2---------------------------------------------------------------
else if (menu2_selected == true)
if (menu2_Value < 9999) //we do not go above 9999
menu2_Value++;
menu2_Value = 0;
if (menu2_Value < 1) //we do not go below 0
menu2_Value = 9999;
// Encoder is rotating in B direction, so decrease
menu2_Value--;
//---MENU3--------------------------------------------------------------- X stop at ColourChanger
else if (menu3_selected == true)
if (menu3_Value < 9999) //we do not go above 9999
menu3_Value++;
menu3_Value = 0;
if (menu3_Value < 1) //we do not go below 0
menu3_Value = 9999;
menu3_Value--;
//---MENU4----------------------------------------------------------------START/PAUSE = HALL EFFECT TRIGGER + DECREMENT
else if (menu4_selected == true)
if (menu1_Value != 0)
menu4_Value = "Started";
// HE Sensor code
// HE Sensor code
int HEreading = digitalRead(DETECT);// read Hall sensor
if ( HEreading == HIGH)
menu1_Value = menu1_Value - 1;
if (menu2_Value != 0)
if (menu2_StoredValue == 0)
menu2_StoredValue = menu2_Value;
menu2_Value = menu2_Value - 1;
if (menu3_Value == 0)
digitalWrite(redRELAY_PIN, LOW); //StopNotColourChanger
digitalWrite(greyRELAY_PIN, HIGH);
if (menu3_Value != 0)
if (menu3_StoredValue == 0)
menu3_StoredValue = menu3_Value;
menu3_Value = menu3_Value - 1;
digitalWrite(redRELAY_PIN, HIGH); //StopColourChanger
delay(150); ////DELAY FOR LIMITING -1 COUNT
HEreading = LOW;
// HE Sensor code
// HE Sensor code
else if (menu1_Value == 0)///RELAY TRIGGER
refreshLCD = true;
else //MENU COUNTER----------------------------------------------------------------------------
if (menuCounter < 3) //we do not go above 3
menuCounter++;
menuCounter = 0;
if (menuCounter < 1) //we do not go below 0
menuCounter = 3;
// Encoder is rotating CW so decrease
menuCounter--;
//Refresh LCD after changing the counter's value
refreshLCD = true;
refreshLCD = true;
void pushButton()
switch (menuCounter)
case 0:
menu1_selected = !menu1_selected; //we change the status of the variable to the opposite
case 1:
menu2_selected = !menu2_selected;
case 2:
menu3_selected = !menu3_selected;
case 3:
menu4_selected = !menu4_selected;
refreshLCD = true; //Refresh LCD after changing the value of the menu
refreshSelection = true; //refresh the selection ("X")
void printLCD() ///MAINMENU NAMING
//These are the values which are not changing the operation
lcd.setCursor(1, 0); //1st line, 2nd block
lcd.print("Rows"); //text
lcd.setCursor(1, 1); //2nd line, 2nd block
lcd.print("Stop"); //text
lcd.setCursor(1, 2); //3rd line, 2nd block
lcd.print("Colour"); //text
lcd.setCursor(1, 3); //4th line, 2nd block
lcd.print("Start"); //text
lcd.setCursor(13, 0); //1st line, 14th block
lcd.print("cnt: "); //counts - text
void updateLCD()
lcd.setCursor(17, 0); //1st line, 18th block
lcd.print(menuCounter); //counter (0 to 3)
lcd.setCursor(9, 0); //1st line, 10th block
if (menu1_Value < 1000) { //hundred
lcd.print ("0");
if (menu1_Value < 100) { //ten
lcd.print ("0");
if (menu1_Value < 10) { //one
lcd.print ("0");
lcd.print(menu1_Value); //print the value of menu1_Value variable
lcd.setCursor(9, 1);
if (menu2_Value < 1000) { //hundred
lcd.print ("0");
if (menu2_Value < 100) { //ten
lcd.print ("0");
if (menu2_Value < 10) { //one
lcd.print ("0");
lcd.print(menu2_Value); //
lcd.setCursor(9, 2);
if (menu3_Value < 1000) { //hundred
lcd.print ("0");
if (menu3_Value < 100) { //ten
lcd.print ("0");
if (menu3_Value < 10) { //one
lcd.print ("0");
lcd.print(menu3_Value); //
lcd.setCursor(9, 3);
lcd.print(menu4_Value); //
void updateCursorPosition()
//Clear display's ">" parts
lcd.setCursor(0, 0); //1st line, 1st block
lcd.print(" "); //erase by printing a space
lcd.print(" ");
lcd.print(" ");
lcd.setCursor(0, 3);
lcd.print(" ");
//Place cursor to the new position
switch (menuCounter) //this checks the value of the counter (0, 1, 2 or 3)
case 0:
lcd.print(">");
case 1:
lcd.setCursor(0, 1); //2nd line, 1st block
lcd.print(">");
case 2:
lcd.setCursor(0, 2); //3rd line, 1st block
lcd.print(">");
case 3:
lcd.setCursor(0, 3); //4th line, 1st block
lcd.print(">");
void updateSelection()
//When a menu is selected ">" becomes "X"
lcd.print("X");
lcd.print("X");
lcd.print("X");
lcd.print("X");
