Let's say i have my host + camera that takes all the decisions regarding torque for each wheel, and that host only has an USB 2.0 output to communicate the desired torque etc to the robots motors.
So. What is the missing/cheapest component that i need ?
It would be nice to have, to include gyro and BT/WIFI to communicate back to my host the position.
I've seen some simple two wheel robot platforms + motors, but i also need a motor driver, correct ?
Do i need to write a HID driver so that my arduino, for example, could interpret what i'm sending ?
From my understanding, arduino just needs to convert what i tell him via USB to some GPIO that are connected to the driver of the motor, correct ?
Scope of the project is a simple robot that just navigates around the room, avoiding obstacles.
It doesn't have GPIOs output, but it has an additional USB port.
The robot chassis could be this: https://www.aliexpress.com/item/32633842302.html
The motors, from their descriptions could be used with L293D driver.
As far as i see, that driver is sold as a shield for Arduino UNO.
So, what i need it my Atom based compute stick talk to the Arduino UNO.
Question: what's the best way to do it ? Can be done via BT/WiFI ? I mean, regarding latency, and if is wise to control motors via PWM using WIFI. The robot is not performing brain surgery, is only roaming around the living room.
Please go get serious advice. That's an old, inefficient, bulky driver.
If that Atom is a USB host, it should be able to connect to the Arduino through the regular USB interface. Your Arduino (forget about the Uno, too bulky - go for a Nano instead) can then receive the commands through USB.
Don't be worried about latency in transmission. Windows itself will take care of introducing that.
