What if* conditions to turn on/off relay
there are several conditions to turn on water pump using relay, conditions are as follows
  1. Time (DS3231) municipal water supply are on timely basis 5.30 to 8.30 am & 4.00 to 8.00 pm
  2. temp of motor should be <63 (DS18B20) as mentioned in motor manual
  3. psi (pressure transducer) min & max defined to protect motor from dry run and over pressure
  4. Ultrasonic sensor (A02YYUW) min & max level to turn on & off auto
  5. Soil moisture sensor (motor installed outside to protect from rain)
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Wire.h>
#include <DS3231.h>
RTClib myRTC;
DateTime now = myRTC.now();
#define Relay1 22
// ds18b20
#define ONE_WIRE_BUS 37
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
// Soil moisture sensor
#define soilSensorPin A11
float soilsensorValue = 0;
// Ultrasonic sensor calc
const int trigPin = 26;
const int echoPin = 27;
int level;
long duration;
int distance;
float water_percentage;
int water_bottom = 160;
int water_top = 25;
int water_distance = 135;
float sensor = 0;
// Pressure transducer
const int pressureInput = A10;
const int pressureZero = 102.4;
const int pressureMax = 921.6;
const int pressuretransducermaxPSI = 100;
const int sensorreadDelay = 250;
float pressureValue = 0;
  sensors.begin();
  Wire.begin();
  pinMode(Relay1, OUTPUT);
  digitalWrite(Relay1, HIGH);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
motorState();
void soilSensor() {
  for (int i = 0; i <= 100; i++)
    soilsensorValue = soilsensorValue + analogRead(soilSensorPin);
    delay(1);
  soilsensorValue = soilsensorValue / 100.0;
  Serial.println(soilsensorValue);
  delay(30);
void usSensor() {
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance = duration * 0.034 / 2;
  water_percentage = (100 * (water_top + water_distance - distance)) / water_distance;
  level = water_percentage;
  sensor = water_percentage;
  Serial.print("wLevel: ");
  Serial.println(sensor);
  delay(250);
void temp() {
  sensors.requestTemperatures();
  Serial.print("temp: ");
  Serial.println(sensors.getTempCByIndex(0));
void psi()  {
  pressureValue = analogRead(pressureInput);
  pressureValue = ((pressureValue - pressureZero) * pressuretransducermaxPSI) / (pressureMax - pressureZero);
  Serial.print("psI: ");
  Serial.println(pressureValue, 1);
  delay(250);
void motorState()  {
  if ((now.hour() >= 5.30 && now.hour() < 8.30) && (now.hour() >= 16.00 && now.hour() < 20.00))
    Serial.println(now.hour());
    if ((psi > 60 && psi < 120) && (temp < 63) && (soilsensorValue < 100))  {
      digitalWrite(Relay1, LOW);
      Serial.println("Motor On");
    else  {
      Serial.println("Motor Off");
Tell us what this says ?
What does this return ? now.hour()
Always show us a good schematic of your proposed circuit.
Show us a good image of your ‘actual’ wiring.
Give links to components.
It is much, much easier to just deal with minutes since midnight. If your RTC is configured to report in 24 hour format, calculate the current minute
int currentMinute = now.hour() * 24 + now.minute();
and then do your time comparison
If your RTC is configured in 12 hour mode (am/pm) then you will have to adjust.
Understandable, I assume. And your code looks a bit creative, but plausible. There are some obvious mistakes, already hinted at. now.hour() is an integer, comparing it to a floating point number, e.g. 5.3, will probably not be doing what it looks like you want.
Do you have a question?
Or observations you can share? What does the code do that it should not? What does the code not do that it should?
a7
consider the following approach
const byte PinMotor = LED_BUILTIN;
int debug;
int hrMin;
const int DegCmax = 63;
int degC;
const int PsiMin = 20;
const int PsiMax = 80;
int psi;
const int SoilMin = 5;
const int SoilMax = 10;
int soil;
int ultra;
enum { Off = HIGH, On = LOW };
// process single character commands from the PC
void
pcRead (void)
    static int  val = 0;
    if (Serial.available()) {
        int c = Serial.read ();
        switch (c)  {
        case '0':
        case '1':
        case '2':
        case '3':
        case '4':
        case '5':
        case '6':
        case '7':
        case '8':
        case '9':
            val = c - '0' + (10 * val);
        case 'D':
            debug ^= 1;
        case 'd':
            degC = val;
            val  = 0;
        case 'm':
            digitalWrite (PinMotor, val);
            val = 0;
        case 'p':
            psi = val;
            val   = 0;
        case 's':
            soil = val;
            val   = 0;
        case 't':
            hrMin = val;
            val   = 0;
        case 'u':
            ultra = val;
            val   = 0;
        case '.':
            Serial.print   (" hrMin "); Serial.println (hrMin);
            Serial.print   (" psi   "); Serial.println (psi);
            Serial.print   (" degC  "); Serial.println (degC);
            Serial.print   (" soil  "); Serial.println (soil);
            Serial.print   (" ultra "); Serial.println (ultra);
        case '?':
            Serial.println ("\npcRead:\n");
            Serial.println ("    [0-9] append to #");
            Serial.println ("    #d - set degC");
            Serial.println ("    #p - set psi");
            Serial.println ("    #s - set soil");
            Serial.println ("    #t - set hrMin");
            Serial.println ("    #u - set ultra");
            Serial.println ("    ?   - list of commands");
        default:
            Serial.print ("unknown char ");
            Serial.println (c,HEX);
void
motorOn (
    bool  on)
    Serial.print  ("motorOn: ");
    Serial.println(on);
    digitalWrite (PinMotor, on);
bool
motorOnTime (void)
    return (530 < hrMin && hrMin < 830) || (1600 < hrMin && hrMin < 2000);
bool motorPsiOk  (void) { return PsiMin <= psi && psi <= PsiMax; }
bool motorTempOk (void) { return degC < DegCmax; }
bool soilOk      (void) { return SoilMin <= soil && soil <= SoilMax; }
void
loop (void)
    if (On == digitalRead (PinMotor))  {
        if (! motorOnTime () || ! motorTempOk () || ! motorPsiOk ()
                || ! soilOk ())
            motorOn (Off);
    else  {
        if (motorOnTime () && motorTempOk () && motorPsiOk ()
                && soilOk ())
            motorOn (On);
    pcRead ();
void
setup (void)
    Serial.begin (9600);
    pinMode      (PinMotor, OUTPUT);
    digitalWrite (PinMotor, Off);
    Serial.println ("ready");
