what is a destructor used for?
when writing a .cpp & .h
if I use the constructor to map my pins etc
when do we use destructors and how would they be used
is it for implementing another library to combine it with the one we are using? ? ?
It gets called when an object is explicitly deleted, or implicitly (when going out of scope) deleted.
Always, when the object is (to be) deleted. If you don’t define on, the compiler will.
The destructor gets called when the instance is explicitly deleted (delete pObject;) or when the object goes out of scope.
Neither.
The question that you didn’t ask is why does one need to explicitly define a destructor, if the compiler will create one for you.
Suppose that in your instance, you dynamically allocate some memory, to store a list of names of files, for instance.
Your object (or instance) goes out of scope (or is deleted). The memory you allocated is NOT freed just because the object (or instance) is deleted. The destructor is supposed to do that.
so say I have a light to flash in my constructor to get someone's attention
but they are blind
so I need to use a speaker/buzzer instead
I might as well turn my light off (disable it)
and just use my speaker/buzzer
is that what your getting at?
