Hello!
I am running arduino-cli 1.1.1 on a Raspberry Pi 4. Basically all commands are very slow. Using --verbose and --log I have come to the conclusion that LoadIndex for library_index.json is causing the slow down. I have cases where LoadIndex takes around a minute for a simple command such as "board list".
Thus my question is, what is LoadIndex with library_index.json actually used for? Is it strictly necessary for correct compilation and upload ?
I have removed the contents of library_index.json, leaving an empty file. This works and the compilation and upload ar still functional.
I believe that library_index.json is part of the mechanism for checking whether library updates are available for download
Hi @rudolfsAER . As @UKHeliBob said, this file provides the data that is used for most of the arduino-cli lib commands:
https://arduino.github.io/arduino-cli/latest/commands/arduino-cli_lib/
These commands provide command line functionality equivalent to the Arduino IDE 's "Library Manager" feature .
I think the only other time it is used is for arduino-cli compile, under the following specific conditions:
You are using a "build profile"
Library dependencies specified by the build profile have not yet been installed in the build profile's isolated dependencies environment
There are 7.5k libraries (each of which may have multiple releases) in the index, so it is a significant quantity of data for Arduino CLI to process.
Thank you for your answer!
I think there may be a bug in the GO implementation for ARM on Raspberry Pi. easyjson Unmarshal has very unpredictable performance. It parses the same library_index.json, but I have cases where it takes 5 minutes and an immediate following run takes 30 seconds, and a third run takes 2 minutes. I have done some GO profiling on the arduino-cli and it seems that it is an issue with GO memory allocation and garbage collection. I have checked for swap usage and thermal throttling, both are not an issue.
Either way for my needs the sketch does not use many libraries and the ones that are used should not be updated dynamically, thus having an empty library_index.json works for me.
Are there any more elegant options, such as a hidden flag to disable LoadIndex in arduino-cli?
Using 1.1.1 on an Pi4 here, and I can't say I've noticed any undue holdups in compilation or upload. Certainly none I could lay at the library index's doorstep. Even doing a library search is finished in about 16 seconds.
I cannot upload files as a new user, so here I have pasted the output for a simple board list. I have also added some version information.
As you can see the LoadIndex is the bottle neck.
rudolfs@raspberrypi:~$ time ~/bin/arduino-cli board list --log --verbose
INFO[0000] arduino-cli version 1.1.1
INFO[0000] Using config file: /home/rudolfs/.arduino15/arduino-cli.yaml
INFO[0000] Checking signature index=/home/rudolfs/.arduino15/package_index.json signatureFile=/home/rudolfs/.arduino15/package_index.json.sig trusted=true
INFO[0000] Loading hardware from: /home/rudolfs/.arduino15/packages
INFO[0000] Loading package ClearCore from: /home/rudolfs/.arduino15/packages/ClearCore/hardware
INFO[0000] Missing signature file index=/home/rudolfs/.arduino15/packages/ClearCore/hardware/sam/1.7.0/installed.json
INFO[0000] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0000] Loaded platform platform="ClearCore:sam@1.7.0"
INFO[0000] Loading package arduino from: /home/rudolfs/.arduino15/packages/arduino
INFO[0000] Checking existence of 'tools' path: /home/rudolfs/.arduino15/packages/arduino/tools
INFO[0000] Loading tools from dir: /home/rudolfs/.arduino15/packages/arduino/tools
INFO[0000] Loaded tool tool="arduino:CMSIS@4.5.0"
INFO[0000] Loaded tool tool="arduino:arm-none-eabi-gcc@7-2017q4"
INFO[0000] Loaded tool tool="arduino:bossac@1.9.1-arduino1"
INFO[0000] Loading package builtin from: /home/rudolfs/.arduino15/packages/builtin
INFO[0000] Checking existence of 'tools' path: /home/rudolfs/.arduino15/packages/builtin/tools
INFO[0000] Loading tools from dir: /home/rudolfs/.arduino15/packages/builtin/tools
INFO[0000] Loaded tool tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool tool="builtin:dfu-discovery@0.1.2"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.9"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.4.1"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.14.1"
INFO[0000] Adding libraries dir dir=/home/rudolfs/.arduino15/packages/ClearCore/hardware/sam/1.7.0/libraries isSingleLibrary=false location=platform
INFO[0000] Loading libraries index file index=/home/rudolfs/.arduino15/library_index.json
INFO[0080] Adding libraries dir dir=/home/rudolfs/Arduino/libraries isSingleLibrary=false location=user
INFO[0080] Executing `arduino-cli board list`
Port Protocol Type Board Name FQBN Core
/dev/ttyACM0 serial Serial Port (USB) Teknic ClearCore ClearCore:sam:clearcore ClearCore:sam
/dev/ttyAMA0 serial Serial Port Unknown
real 1m21.635s
user 1m1.591s
sys 1m38.845s
rudolfs@raspberrypi:~$ uname -a
Linux raspberrypi 5.4.0-1069-raspi #79-Ubuntu SMP PREEMPT Thu Aug 18 18:15:22 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux
rudolfs@raspberrypi:~$ go version
go version go1.23.5 linux/arm64
rudolfs@raspberrypi:~$ ~/bin/arduino-cli version
arduino-cli Version: 1.1.1 Commit: fa6eafcb Date: 2024-11-22T09:31:36Z
Under 5 seconds total here.
me@home:~/Documents/sketchbook/Uno_R3/blink $ time ~/bin/arduino-cli board list --log --verbose
INFO[0000] Using config file: /home/me/.arduino15/arduino-cli.yaml
INFO[0000] Checking signature index=/home/me/.arduino15/package_index.json signatureFile=/home/me/.arduino15/package_index.json.sig trusted=true
INFO[0000] Missing signature file index=/home/me/.arduino15/package_teensy_index.json
INFO[0000] Missing signature file index=/home/me/.arduino15/package_esp32_index.json
INFO[0000] Missing signature file index=/home/me/.arduino15/package_drazzy.com_index.json
INFO[0000] Missing signature file index=/home/me/.arduino15/package_DFRobot_index.json
INFO[0000] Missing signature file index=/home/me/.arduino15/package_MCUdude_MiniCore_index.json
INFO[0000] Missing signature file index=/home/me/.arduino15/package_MCUdude_MegaCoreX_index.json
INFO[0000] Missing signature file index=/home/me/.arduino15/package_rp2040_index.json
INFO[0000] Loading hardware from: /home/me/.arduino15/packages
INFO[0000] Loading package ATTinyCore from: /home/me/.arduino15/packages/ATTinyCore/hardware
INFO[0000] Missing signature file index=/home/me/.arduino15/packages/ATTinyCore/hardware/avr/1.5.2/installed.json
INFO[0000] Loaded platform platform="ATTinyCore:avr@1.5.2"
INFO[0000] Checking existence of 'tools' path: /home/me/.arduino15/packages/ATTinyCore/tools
INFO[0000] Loading tools from dir: /home/me/.arduino15/packages/ATTinyCore/tools
INFO[0000] Loaded tool tool="ATTinyCore:micronucleus@2.5-azd1b"
INFO[0000] Loading package DFRobot from: /home/me/.arduino15/packages/DFRobot/hardware
INFO[0000] Missing signature file index=/home/me/.arduino15/packages/DFRobot/hardware/esp32/0.2.1/installed.json
INFO[0000] Loaded platform platform="DFRobot:esp32@0.2.1"
INFO[0000] Checking existence of 'tools' path: /home/me/.arduino15/packages/DFRobot/tools
INFO[0000] Loading tools from dir: /home/me/.arduino15/packages/DFRobot/tools
INFO[0000] Loaded tool tool="DFRobot:esptool_py@3.0.0"
INFO[0000] Loaded tool tool="DFRobot:mkspiffs@0.2.3"
INFO[0000] Loaded tool tool="DFRobot:xtensa-esp32-elf-gcc@gcc8_4_0-esp-2020r3"
INFO[0000] Loaded tool tool="DFRobot:xtensa-esp32s2-elf-gcc@gcc8_4_0-esp-2020r3"
INFO[0000] Loading package MegaCoreX from: /home/me/.arduino15/packages/MegaCoreX/hardware
INFO[0000] Missing signature file index=/home/me/.arduino15/packages/MegaCoreX/hardware/megaavr/1.1.3/installed.json
INFO[0000] Loaded platform platform="MegaCoreX:megaavr@1.1.3"
INFO[0000] Checking existence of 'tools' path: /home/me/.arduino15/packages/MegaCoreX/tools
INFO[0000] Loading tools from dir: /home/me/.arduino15/packages/MegaCoreX/tools
INFO[0000] Loaded tool tool="MegaCoreX:avrdude@8.0-arduino.1"
INFO[0000] Loading package MiniCore from: /home/me/.arduino15/packages/MiniCore/hardware
INFO[0000] Missing signature file index=/home/me/.arduino15/packages/MiniCore/hardware/avr/3.0.3/installed.json
INFO[0000] Loaded platform platform="MiniCore:avr@3.0.3"
INFO[0000] Checking existence of 'tools' path: /home/me/.arduino15/packages/MiniCore/tools
INFO[0000] Loading tools from dir: /home/me/.arduino15/packages/MiniCore/tools
INFO[0000] Loaded tool tool="MiniCore:avrdude@8.0-arduino.1"
INFO[0000] Loading package STM32 from: /home/me/.arduino15/packages/STM32/hardware
INFO[0000] Loaded platform platform="STM32:STM32F1@0.1.2"
INFO[0000] Loaded platform platform="STM32:STM32F4@0.1.0"
INFO[0000] Loaded platform platform="STM32:drivers@"
INFO[0000] Checking existence of 'tools' path: /home/me/.arduino15/packages/STM32/tools
INFO[0000] Loading tools from dir: /home/me/.arduino15/packages/STM32/tools
INFO[0000] Loaded tool tool="STM32:linux@dfu-util"
INFO[0000] Loaded tool tool="STM32:linux@src"
INFO[0000] Loaded tool tool="STM32:linux@stlink"
INFO[0000] Loaded tool tool="STM32:linux@stm32flash"
INFO[0000] Loaded tool tool="STM32:linux64@dfu-util"
INFO[0000] Loaded tool tool="STM32:linux64@src"
INFO[0000] Loaded tool tool="STM32:linux64@stlink"
INFO[0000] Loaded tool tool="STM32:linux64@stm32flash"
INFO[0000] Loaded tool tool="STM32:macosx@dfu-util"
INFO[0000] Loaded tool tool="STM32:macosx@src"
INFO[0000] Loaded tool tool="STM32:macosx@stlink"
INFO[0000] Loaded tool tool="STM32:macosx@stm32flash"
INFO[0000] Loaded tool tool="STM32:win@dfu-util-0.9-win64"
INFO[0000] Loaded tool tool="STM32:win@hid_flash"
INFO[0000] Loaded tool tool="STM32:win@lib"
INFO[0000] Loaded tool tool="STM32:win@src"
INFO[0000] Loaded tool tool="STM32:win@stlink"
INFO[0000] Loaded tool tool="STM32:win@texane-stlink"
INFO[0000] Loading package SparkFun from: /home/me/.arduino15/packages/SparkFun/hardware
INFO[0000] Loaded platform platform="SparkFun:avr@1.1.13"
INFO[0000] Loading package adafruit from: /home/me/.arduino15/packages/adafruit/hardware
INFO[0000] Loaded platform platform="adafruit:samd@1.5.10"
INFO[0000] Loading package arduino from: /home/me/.arduino15/packages/arduino/hardware
INFO[0000] Missing signature file index=/home/me/.arduino15/packages/arduino/hardware/avr/1.8.3/installed.json
INFO[0000] Loaded platform platform="arduino:avr@1.8.3"
INFO[0000] Missing signature file index=/home/me/.arduino15/packages/arduino/hardware/megaavr/1.8.8/installed.json
INFO[0000] Loaded platform platform="arduino:megaavr@1.8.8"
INFO[0000] Missing signature file index=/home/me/.arduino15/packages/arduino/hardware/renesas_uno/1.3.1/installed.json
INFO[0000] Loaded platform platform="arduino:renesas_uno@1.3.1"
INFO[0000] Loaded platform platform="arduino:sam@1.6.12"
INFO[0000] Missing signature file index=/home/me/.arduino15/packages/arduino/hardware/samd/1.8.14/installed.json
INFO[0000] Loaded platform platform="arduino:samd@1.8.14"
INFO[0000] Checking existence of 'tools' path: /home/me/.arduino15/packages/arduino/tools
INFO[0000] Loading tools from dir: /home/me/.arduino15/packages/arduino/tools
INFO[0000] Loaded tool tool="arduino:CMSIS-Atmel@1.2.0"
INFO[0000] Loaded tool tool="arduino:arduinoOTA@1.1.1"
INFO[0000] Loaded tool tool="arduino:arduinoOTA@1.2.1"
INFO[0000] Loaded tool tool="arduino:arduinoOTA@1.3.0"
INFO[0000] Loaded tool tool="arduino:arm-none-eabi-gcc@4.8.3-2014q1"
INFO[0000] Loaded tool tool="arduino:avr-gcc@4.9.2-atmel3.5.4-arduino2"
INFO[0000] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino5"
INFO[0000] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0000] Loaded tool tool="arduino:avrdude@6.3.0-arduino17"
INFO[0000] Loaded tool tool="arduino:avrdude@6.3.0-arduino18"
INFO[0000] Loaded tool tool="arduino:avrdude@6.3.0-arduino9"
INFO[0000] Loaded tool tool="arduino:bossac@1.6.1-arduino"
INFO[0000] Loaded tool tool="arduino:bossac@1.7.0"
INFO[0000] Loaded tool tool="arduino:bossac@1.7.0-arduino3"
INFO[0000] Loaded tool tool="arduino:bossac@1.8.0-48-gb176eee"
INFO[0000] Loaded tool tool="arduino:bossac@1.9.1-arduino5"
INFO[0000] Loaded tool tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0000] Loaded tool tool="arduino:openocd@0.10.0-arduino7"
INFO[0000] Loaded tool tool="arduino:openocd@0.11.0-arduino2"
INFO[0000] Loaded tool tool="arduino:openocd@0.9.0-arduino"
INFO[0000] Loading package attiny from: /home/me/.arduino15/packages/attiny/hardware
INFO[0000] Loaded platform platform="attiny:avr@1.0.2"
INFO[0000] Loading package builtin from: /home/me/.arduino15/packages/builtin
INFO[0000] Checking existence of 'tools' path: /home/me/.arduino15/packages/builtin/tools
INFO[0000] Loading tools from dir: /home/me/.arduino15/packages/builtin/tools
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.6"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.8"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.3.2"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.3.5"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.4.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.10.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.12.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.13.0"
INFO[0000] Loading package esp32 from: /home/me/.arduino15/packages/esp32/hardware
INFO[0000] Missing signature file index=/home/me/.arduino15/packages/esp32/hardware/esp32/2.0.14/installed.json
INFO[0000] Loaded platform platform="esp32:esp32@2.0.14"
INFO[0000] Checking existence of 'tools' path: /home/me/.arduino15/packages/esp32/tools
INFO[0000] Loading tools from dir: /home/me/.arduino15/packages/esp32/tools
INFO[0000] Loaded tool tool="esp32:esptool_py@4.5.1"
INFO[0000] Loaded tool tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0000] Loaded tool tool="esp32:mkspiffs@0.2.3"
INFO[0000] Loaded tool tool="esp32:openocd-esp32@v0.12.0-esp32-20230419"
INFO[0000] Loaded tool tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0000] Loaded tool tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0000] Loaded tool tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0000] Loaded tool tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0000] Loaded tool tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0000] Loaded tool tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0000] Loading package esp8266 from: /home/me/.arduino15/packages/esp8266/hardware
INFO[0000] Loaded platform platform="esp8266:esp8266@2.6.3"
INFO[0000] Checking existence of 'tools' path: /home/me/.arduino15/packages/esp8266/tools
INFO[0000] Loading tools from dir: /home/me/.arduino15/packages/esp8266/tools
INFO[0000] Loaded tool tool="esp8266:mklittlefs@2.5.0-4-69bd9e6"
INFO[0000] Loaded tool tool="esp8266:mkspiffs@2.5.0-4-b40a506"
INFO[0000] Loaded tool tool="esp8266:python3@3.7.2-post1"
INFO[0000] Loaded tool tool="esp8266:xtensa-lx106-elf-gcc@2.5.0-4-b40a506"
INFO[0000] Loading package rp2040 from: /home/me/.arduino15/packages/rp2040/hardware
INFO[0000] Missing signature file index=/home/me/.arduino15/packages/rp2040/hardware/rp2040/4.3.1/installed.json
INFO[0000] Loaded platform platform="rp2040:rp2040@4.3.1"
INFO[0000] Checking existence of 'tools' path: /home/me/.arduino15/packages/rp2040/tools
INFO[0000] Loading tools from dir: /home/me/.arduino15/packages/rp2040/tools
INFO[0000] Loaded tool tool="rp2040:pqt-gcc@4.0.1-8ec9d6f"
INFO[0000] Loaded tool tool="rp2040:pqt-gcc-riscv@4.0.1-8ec9d6f"
INFO[0000] Loaded tool tool="rp2040:pqt-mklittlefs@4.0.1-8ec9d6f"
INFO[0000] Loaded tool tool="rp2040:pqt-openocd@4.0.1-8ec9d6f"
INFO[0000] Loaded tool tool="rp2040:pqt-picotool@4.0.1-8ec9d6f"
INFO[0000] Loaded tool tool="rp2040:pqt-pioasm@4.0.1-8ec9d6f"
INFO[0000] Loaded tool tool="rp2040:pqt-python3@1.0.1-base-3a57aed-1"
INFO[0000] Loading package teensy from: /home/me/.arduino15/packages/teensy/hardware
INFO[0000] Missing signature file index=/home/me/.arduino15/packages/teensy/hardware/avr/1.57.2/installed.json
INFO[0000] Adding monitor tool protocol=teensy tool="teensy:teensy-monitor"
INFO[0000] Loaded platform platform="teensy:avr@1.57.2"
INFO[0000] Checking existence of 'tools' path: /home/me/.arduino15/packages/teensy/tools
INFO[0000] Loading tools from dir: /home/me/.arduino15/packages/teensy/tools
INFO[0000] Loaded tool tool="teensy:teensy-compile@5.4.1"
INFO[0000] Loaded tool tool="teensy:teensy-discovery@1.57.2"
INFO[0000] Loaded tool tool="teensy:teensy-monitor@1.57.2"
INFO[0000] Loaded tool tool="teensy:teensy-tools@1.57.2"
INFO[0000] Loading hardware from: /home/me/Documents/sketchbook/hardware
INFO[0000] Searching tools required for platform rp2040:rp2040@4.3.1
INFO[0000] Adding libraries dir dir=/home/me/.arduino15/packages/STM32/hardware/STM32F1/libraries isSingleLibrary=false location=platform
INFO[0000] Adding libraries dir dir=/home/me/.arduino15/packages/STM32/hardware/STM32F4/libraries isSingleLibrary=false location=platform
INFO[0000] Adding libraries dir dir=/home/me/.arduino15/packages/adafruit/hardware/samd/1.5.10/libraries isSingleLibrary=false location=platform
INFO[0000] Adding libraries dir dir=/home/me/.arduino15/packages/ATTinyCore/hardware/avr/1.5.2/libraries isSingleLibrary=false location=platform
INFO[0000] Adding libraries dir dir=/home/me/.arduino15/packages/esp8266/hardware/esp8266/2.6.3/libraries isSingleLibrary=false location=platform
INFO[0000] Adding libraries dir dir=/home/me/.arduino15/packages/DFRobot/hardware/esp32/0.2.1/libraries isSingleLibrary=false location=platform
INFO[0000] Adding libraries dir dir=/home/me/.arduino15/packages/teensy/hardware/avr/1.57.2/libraries isSingleLibrary=false location=platform
INFO[0000] Adding libraries dir dir=/home/me/.arduino15/packages/MiniCore/hardware/avr/3.0.3/libraries isSingleLibrary=false location=platform
INFO[0000] Adding libraries dir dir=/home/me/.arduino15/packages/MegaCoreX/hardware/megaavr/1.1.3/libraries isSingleLibrary=false location=platform
INFO[0000] Adding libraries dir dir=/home/me/.arduino15/packages/SparkFun/hardware/avr/1.1.13/libraries isSingleLibrary=false location=platform
INFO[0000] Adding libraries dir dir=/home/me/.arduino15/packages/arduino/hardware/renesas_uno/1.3.1/libraries isSingleLibrary=false location=platform
INFO[0000] Adding libraries dir dir=/home/me/.arduino15/packages/arduino/hardware/avr/1.8.3/libraries isSingleLibrary=false location=platform
INFO[0000] Adding libraries dir dir=/home/me/.arduino15/packages/arduino/hardware/samd/1.8.14/libraries isSingleLibrary=false location=platform
INFO[0000] Adding libraries dir dir=/home/me/.arduino15/packages/arduino/hardware/sam/1.6.12/libraries isSingleLibrary=false location=platform
INFO[0000] Adding libraries dir dir=/home/me/.arduino15/packages/arduino/hardware/megaavr/1.8.8/libraries isSingleLibrary=false location=platform
INFO[0000] Adding libraries dir dir=/home/me/.arduino15/packages/esp32/hardware/esp32/2.0.14/libraries isSingleLibrary=false location=platform
INFO[0000] Adding libraries dir dir=/home/me/.arduino15/packages/rp2040/hardware/rp2040/4.3.1/libraries isSingleLibrary=false location=platform
INFO[0000] Loading libraries index file index=/home/me/.arduino15/library_index.json
INFO[0002] Adding libraries dir dir=/home/me/Documents/sketchbook/libraries isSingleLibrary=false location=user
WARN[0003] Error loading library error="rpc error: code = Internal desc = loading library from /home/me/.arduino15/packages/adafruit/hardware/samd/1.5.10/libraries/CI_Tests: invalid library: no header files found"
INFO[0003] Executing `arduino-cli board list`
192.168.60.32 network Network Port Unknown
real 0m4.634s
user 0m2.742s
sys 0m1.057s
Can you please post your output of uname -a and go version?
No go installed, and uname -a is Linux home 6.1.21-v7l+ #1642 SMP Mon Apr 3 17:22:30 BST 2023 armv7l GNU/Linux.
system
Closed
July 23, 2025, 7:30am
10
