What is bitshifting?
While lazily searching solutions for my simple unrelated problem, i noticed that almost everyone used these weird "<<" and ">>" operators. I know this is called bitshifting, but what does it do?
might help,
Bitshifting refers to moving the bits of a variable left or right to change its value
Try this
byte x = 0b00000001;
  Serial.println(x, BIN);
  for (int b = 0; b < 7; b++)
    x = x << 1; //left shift 1 bit
    Serial.print(x);
    Serial.print(" ");
NOTE : When using the BIN format specifier leading zeroes are not printed
This may be clearer
  printBin();
    printBin();
void printBin()
  Serial.print(x);
  Serial.print("\t");
  for (int b = 7; b > 0; b--)
    Serial.print(bitRead(x, b));
byte x = 0b00010000;
byte y = x << 1;
So y now = 0b00100000
The bits have been shifted left 1 bit.
"<<" shift left. Left most bit is lost, and right most bit becomes 0.
">>" shift right. Right most bit is lost, and left most bit becomes 0.
The number after the operator determines how many places you shift.
