What is byte in code for motors?
Hello, I am taking part in an robotics contest and they provided a basic code but I don't understand how byte works. I tried changing the values of it but when I did my robot isn't working. Also the driver for motors is an unique one and doesn't have 2 pins for one motor but one. Also the code is in a program called Mixly in which you can code using blocks.(Also inceput=begging, inainte=forward, inapoi=backwards, stare=state, senzorDreapta=sensorRight and sezorStanga=sensorLeft. Sorry for the inconvinience, the words are in romanian.)
volatile byte inceput;
volatile byte inainte;
volatile byte inapoi;
volatile int stare;
volatile int senzorStanga;
volatile int senzorDreapta;
void setup(){
  pinMode(3, INPUT);
  pinMode(9, INPUT);
  inceput = 254;
  inainte = 240;
  inapoi = 186;
  stare = 0;
  senzorStanga = 0;
  senzorDreapta = 0;
  pinMode(3, INPUT);
  pinMode(9, INPUT);
void loop(){
  senzorStanga = digitalRead(3);
  senzorDreapta = digitalRead(9);
  if (senzorStanga == 1) {
    if (senzorDreapta == 1) {
      stare = 0;
      stare = 1;
  } else if (senzorDreapta == 1) {
    stare = -1;
  switch (stare) {
   case -1:
    Serial.write(inceput);
    Serial.write(1);
    Serial.write(inainte);
    Serial.write(50);
    Serial.write(2);
    Serial.write(0);
   case 1:
    Serial.write(1);
    Serial.write(0);
    Serial.write(2);
    Serial.write(50);
   default:
    Serial.write(1);
    Serial.write(50);
    Serial.write(2);
    Serial.write(50);
I don't need any fixing for the program as it already works I just need to understand how byte works.
Thanks
byte is a data type, just an alias for 'unsigned char' which is an 8 bit variable.
The word "byte" tells the compiler to reserve one byte (8 bits) of space for the variable. A byte can hold values between 0 and 255
If the code was volatile int inceput; the compiler would reserve space for an integer (2 bytes or 16 bits) which could hold a value between -32768 and +32767
Read about Data Types in the Reference section.
...R
