Hello!
This is my first time reaching out to an online community about coding help. I hope I'm doing everything correctly, but let me know if I need to fix anything.
I'm trying to make an automatic plant waterer. There are 3 phases of my code: initialization, checkMoisture / determining if water is needed, and waitBeforeNextScan() method/wait until the next read cycle. Initialization will find the initial state of the water and find the average. Then the checkMoisture method should take values from the water sensor, find an average over 3 seconds, and check whether the plant needs water by seeing if the average water value is too low from the initial average found in the initialization phase. The waitBeforeNextScan() method should simply wait 5 seconds then allow the checkMoisture method to run again. This cycle should continue on forever.
Right now I’m facing an issue that causes the program to spam/repeat without waiting between the checkMoisture method and the waitBeforeNextScan method. The serial print statements look fine and all in order but I think there may be a timing or even a memory problem that causes this issue. I tried changing/printing the values of the time to wait and the boolean values that control what phase of code is running but I can't figure it out. There aren't any error messages that are posted when I compile and run the program.
I am using an ARDUINO UNO R3 - SMD, a Songhe Rain Water Level Sensor, and an Arducam 1602 16x2 LCD Display.
Thank you for anyone reading all this and for helping me out. I appreciate it a lot!
#include <Array.h>
#include <Wire.h>
#include <Stepper.h>
int waterInputPin = A0;
int buttonInputPin = 9;
LiquidCrystal_I2C lcd (0x27, 16, 2);
int start;
int waterVal = 0;
int eventInterval = 1000;
const int totalScanLength = 3;
int highestAverageMoisture[totalScanLength];
int averageSum = 0;
int arrayLength = sizeof(highestAverageMoisture) / sizeof(highestAverageMoisture[0]);
int timeTillNextScan = 5;
bool wait = false;
bool shouldScan = false;
int initialSetupStep = 0;
int arrayIndex = 0;
int timePassed = 0;
int fullSaturation = 0;
int threeFourthSaturation = 0;
int halfSaturation = 0;
int dryBoi = 0;
// LEDs for testing spammingIssue
int leftLED = 11;
int middleLED = 12;
int rightLED = 13;
pinMode(leftLED, OUTPUT);
pinMode(middleLED, OUTPUT);
pinMode(rightLED, OUTPUT);
lcd.begin(16, 2);
lcd.backlight();
lcd.setCursor(0, 0);
lcd.print("Hello There!");
Serial.println("--------------");
Serial.println("Starting System");
} // end of setup
waterVal = analogRead(waterInputPin);
initialSetup();
checkMoisture();
waitBeforeNextScan();
void checkMoisture()
if(millis() - start >= eventInterval && timePassed < totalScanLength && shouldScan)
digitalWrite(leftLED, LOW);
digitalWrite(middleLED, HIGH);
digitalWrite(rightLED, LOW);
// this will pass data from water sensor into array
// if time is almost up we will continue getting the values
// when time is up we will get the final value in the else statement
if(timePassed < totalScanLength - 1)
timePassed++;
highestAverageMoisture[arrayIndex] = waterVal;
Serial.println(highestAverageMoisture[arrayIndex]);
arrayIndex++;
start = millis();
}else
// find average of moisture
for(int x = 0; x < arrayLength; x++)
averageSum += highestAverageMoisture[x];
Serial.print("Average : ");
Serial.println(averageSum / arrayLength);
// determine if water is needed
if ((averageSum / arrayLength) <= halfSaturation)
Serial.println("Needs water");
}else
Serial.println("Still moist");
clearArray();
// settings for next method
timePassed = 0;
shouldScan = false;
wait = true;
start = millis();
void waitBeforeNextScan()
if(millis() - start >= eventInterval && timePassed < timeTillNextScan && wait)
digitalWrite(middleLED, LOW);
digitalWrite(rightLED, HIGH);
if(timePassed < timeTillNextScan - 1)
timePassed++;
Serial.println(timePassed);
start = millis();
}else
timePassed++;
shouldScan = true;
wait = false;
timePassed = 0;
Serial.println("Wait Complete");
start = millis();
void createLevelsOfMoisture(int average)
fullSaturation = average;
threeFourthSaturation = average * 0.75;
halfSaturation = average / 2;
dryBoi = average / 5;
// values for next phase
timePassed = 0;
shouldScan = true;
start = millis();
int initialSetup()
if(digitalRead(buttonInputPin) == HIGH && initialSetupStep == 0)
digitalWrite(leftLED, HIGH);
while(digitalRead(buttonInputPin) == HIGH) {}
Serial.println("Placed in soil");
initialSetupStep++;
start = millis();
//long currentTime = millis();
// every second, for totalScanLength : get moisture of water
if(millis() - start >= eventInterval && timePassed < totalScanLength && initialSetupStep == 1)
Serial.println(waterVal);
arrayIndex++;
start = millis();
timePassed++;
// get the last value
arrayIndex++;
start = millis();
timePassed++;
// move onto next part of code: finding average
initialSetupStep++;
// if scan is complete. find average
if(initialSetupStep == 2)
Serial.println("Find average");
createLevelsOfMoisture(averageSum / arrayLength);
clearArray();
initialSetupStep++;
}// end of initialWaterReading
void clearArray()
highestAverageMoisture[x] = 0;
averageSum = 0;
arrayIndex = 0;
Serial.println("array cleared");
