what is code of digital servo ?
the uses digital servo : HK15298B High Voltage Coreless Digital MG/BB Servo
Spec. Torque: 18kg @ 6v, 20kg @ 7.4v Weight: 66g Speed: 0.18 / 60deg @ 6v, 0.16 / 60deg @ 7.4v Voltage: 4.8v~7.4v Motor type: Coreless Plug: JR Style
i wanna it move 90 degree ... i know cant use sweep code so if anyone have idea to help . thx
Why not? It says it's a servo so it should respond like any other servo.
Link us a datasheet which says it won't work.
the link of servo http://www.hobbyking.com/hobbyking/store/__16272__HobbyKing_8482_Coreless_Digital_HV_MG_BB_Servo_66g_20kg_0_16s.html
From what I read here, a digital servo is controlled by the same signal as an analog one; the difference is the way in which that signal is processed inside the servo.
no there are different between analog and digital .. when use sweep code it move only 90 degree
Some digital servos only move 90 deg full range (this is the normal full range for RC operation). Some digital servos can be reprogrammed to move 180 deg. If your servo is programmable you might be able to change the range.
it move 90 degree when use sweep code , but when change it and use writemicroseconds it move to 180 but not make any delay
