I have written my first Arduino programme and am getting some strange results The sketch is about 20,000 bytes and when I check the RAM when running it's saying 358 is free. Is this considered low enough to cause problems. I know there is 2 k to play with, but I'm using the Adafruit WAVEHC library and the NewPing one.
thanks for that.. that is what I am currently doing... I was just wondering what was considered low. ie my RAM says there is 350 is free and I'm sure my problems are related to low RAM... So would 350f be considered low enough to cause issues.
You don't have to have any free as a margin. You just need to know that at the most costly point in your code that you haven't run the stack into the heap.
Low Ram is a relative concept. If you're doing recursive factorials, 350 bytes might look like a lot until you change 5! to 10!. If you have a defined task that uses a fixed variable allocations, you might get away with as little as 25 bytes of RAM left. Your design should be able to give you at least an approximate count of the RAM you will need.
arawire:
thanks for that ... so I gather from what you're saying is that below 10% free ie on the Uno 200 is where you may get into a pickle?
No I just picked 10% to show you you have plenty left.
As noted above, you don't need any free RAM. All you have to watch out for is that if you don't have any free you can't use any more. Apart from that everything is good!
yes .. thanks, i totally understand .. I just felt a bit guilty about dumping lots of code for someone to look at so I was trying to be more concise. I'll post it up tomorrow..
BTW.. I removed all the string references and freed up another 150 bytes RAM.. So Thanks
OK, I'm posting the code here - so any pointers would be great. It is my first Arduino program so if you could be gentle that would be great and explain any wrong coding as if you were to a child. Just to summarize, I have one ultrasonic sensor, and Adafruit wave shield that plays speech based on "assumed movement". I've managed to reduce RAM drastically by using ints, getting rid of strings and switch statements .. problem is now that when I press the button for the calibration routine in the void playUntilBlocked it restarts itself.. I think specifically on the wave.stop. Comments on the code would be much appreciated (bear in mind it's not finished). Thanks
... it says the code is too big so I'm attaching it as a text file.
