Hi all,
I'm new on electronics and programming.
I was searching on the Web about a low frequency data transmitter. Also on circuit I saw the data input ENB and TXO. My question is what is ENB and TXO. I searched on Internet about it but I couldn't find anything.
Thanks for your time.
(deleted)
Generally speaking, when you see abbreviations for pins, they are that way because that's what's used in the relevant datasheet; the datasheet in question will almost always describe the function of the pin, and you should always read the relevant datasheets.
Datasheets are our bible - a source of truth and guidance from the creator (of the part) expressed in dense and obtuse language.
TXO and RXI are "Transmit Out" and "Receive In" - an attempt to address the confusion surrounding serial, since the RX of one device has to go to the TX of the other device. So you write TX next to one pin, and RX next to the other. But does that mean I connect TX to the pin marked TX, or that that pin is TX of the device, so it needs to go to RX? TXO and RXI eliminates that ambiguity by making it clear that the TXO is the TX of the device, not the pin to connect to TX.
EN is commonly used for an "Enable" pin. Sometimes there are multiple enable pins, which may get names like ENA, ENB, etc.
If you see a pin named with a line over the name, that almost always indicates that the pin is active low (though the absence of such a line does not necessarily imply the opposite).
Thanks both of you for your answers and time.
For more detailed this is the circuit http://www.next.gr/circuits/FM-FSK-27MHz-transmitter-circuit-l51271.html
I'm wondering what's the use of enable here and where does the antenna connected? On TXO? Maybe it's a stupid question sorry! ![]()
I was about to say that nobody in their right mind would label an RF output "TXO"...then I looked at the circuit.
It seems that's exactly what they have done.
And ENB does seem to be an enable input, one would assume active high but who knows.
"It can provide 10 communications."
What does that even mean?
Personally I would either get some real documentation or move on to a vendor that supplies real documentation. You will need to know how to drive this as well as rigging up the hardware.
Thanks for your reply also in this circuit I could make a servo transmitter? For example if I connect "data in" pin on a digital pin of arduino with "knob" arduino example and in the other side I have a receiver on this band this will work?
this will work?
No.
You would need to read the value on the pot pin of Arduino 1, transmit the value to Arduino 2, extract the value from the incoming message and apply it to the servo.
Yes of course to read pot first.. also I don't understand what enable pin really do
