what is error in this codes please help me
int X=0;
X=sum(5,4);
Serial.println(x);
int  sum(int firstNum , int secondNum);
int  result =0;
result = firstNum + secondNum ;
return result ;
error
'sum' was not declared in this scope
You have to declare a prototype of the function before its first use/call
or move the function definition above.
Next problem is a semicolon in a definition. It should be:
You usually don't have to declare the prototype when using the Arduino IDE.The builder takes care of that.
You however did create a prototype by accident. As said above, remove that semicolon.
sterretje:
Ahh, yes it could work without. I am still using v1.0.6 without such feature.
Budvar10:
thanks you and thanks again for forum i love you
Budvar10:
1.0.6 has automatic prototype generation. It's not quite as good as in the latest IDE versions but the times when it fails are still pretty rare. Once the bugs are fixed in sky1981's code, it will compile quite happily in 1.0.6 without a prototype for sum.
