What is exif.h ?
I'm sorry for poor recognition.
I want to use Aruduino for IOT,and I'm not understand the program, so use AI for making program.
But AI made program is not correct and check this word in the verify.
please teach me what is the "exif.h" ,and where is the library?
My standard advice:
Keep asking the robot until he/she/it gives you the correct result you expect.
One answer could probably be 42.
You're missing a library; if AI did not tell you which one it used, you have a problem. One of the first hits in arduino exif.h - Google Search is
GitHub - bitbank2/JPEGDEC: An optimized JPEG decoder for Arduino; it however is not said that it's the correct library or that it will work with the Arduino that you are using.
AI might also very well have generated code for a PC.
Please post your code and please post your complete error message. Please read How to get the best out of this forum how to use code tags for both the code and the error message.
Your topic has been moved to a more suitable location on the forum. Please see Uncategorized - Arduino Forum why you should not post in "Uncategorized"
AI gave you the program you need AI to debug it for you.
Hi....
shigel, exif.h is a library that read data from image files. This library is not made for IoT projects.
Thank you for your advise.
I will try question to AI.
Thank you for advise.
Maybe AI misunderstood my request.
I am sorry for written at wrong category.
And thank you for your reply.
My standard advice:
