what is format to make digitalWrite variable?
Is it possible to just change the variable in each pass of digitalWrite and if so, what is the format?
 for (i=10;i<14;i++)
    digitalWrite(led(i), HIGH);   // turn the LED on
    delay(10);               // wait for a second
    digitalWrite(led(i), LOW);
    delay(10);
Doing this just returns
led not assigned.
I have tried (led’i’, HIGH); with the same error instruction.
Which format is it?
thanks.
Would work if "led" is function returning a pin number and digitalWrite(led[i], HIGH); will work if "led" is an array.
digitalWrite(i, HIGH);
Or make led an array. Use
byte led[ ] = {10, 11, 12, 13,};
for (i=0; i<4; i=i+1){
pinMode (led[i], OUTPUT);
and then
for (i=0;i<4;i++)
    digitalWrite(led[i], HIGH);   // turn the LED on
    digitalWrite(led[i], LOW);
    delay(10);
Some names are system names and cannot be used. led might be one of them.
try ledPin if you see some error statements about that.
I have
int i;
int led2=2;
int led3=3;
int led4=4;
int led5=5;
int led10=10;
int led11=11;
int led12=12;
int led13=13;
  pinMode(led2,OUTPUT);
  pinMode(led5,OUTPUT);
  pinMode(led10,OUTPUT);
  pinMode(led11,OUTPUT);
  pinMode(led12,OUTPUT);
  pinMode(led13,OUTPUT);
  digitalWrite(led2,LOW);
  leds();
  digitalWrite(led2,HIGH);
 digitalWrite(led3,LOW);
  leds();
  digitalWrite(led3,HIGH);
  digitalWrite(led4,LOW);
  leds();
  digitalWrite(led4,HIGH);
  digitalWrite(led5,LOW);
  leds();
  digitalWrite(led5,HIGH);
void leds()
  for (i=10;i<14;i++)
    digitalWrite(led(i), HIGH);   // turn the LED on (HIGH is the voltage level)
and I get the first digitalWrite line lit up yellow and
‘led’ was not declared in this scope
if I try to compile it.
int led [ ] ={2, 3, 4, 5, 10, 11, 12, 13};
And use the arrya form I showed.
No Bob It still gives ledPIn not recognised
int i;
int led2=2;
int led3=3;
int led4=4;
int led5=5;
int ledPin10=10;
int ledPin11=11;
int ledPin12=12;
int ledPin13=13;
  pinMode(ledPin10,OUTPUT);
  pinMode(ledPin11,OUTPUT);
  pinMode(ledPin12,OUTPUT);
  pinMode(ledPin13,OUTPUT);
  leds();
 /* digitalWrite(led3,LOW);
  leds();
  leds();
  digitalWrite(led4,HIGH);  */
  leds();
void leds()
  for (i=10;i<14;i++)
    digitalWrite(ledPin(i), HIGH);   // turn the LED on (HIGH is the voltage level)
    digitalWrite(ledPin(i), LOW);    // turn the LED off by making the voltage LOW
I have changed it all the way through the program with no improvement?
AWOL I was hoping to do it this way.
So make an array, will duplicate the info of led2, led3, led4, etc.
byte ledPin[] = {2,3,4,5,10,11,12,13,}; // elements 0 to 7   << declare this with the variables
for (i=0; i<8; i=i+1){
pinMode (ledPin[i], OUTPUT);
and
for (i=4;i<8;i++) // 10,11,12,13 to switch
    digitalWrite(ledPin[i], HIGH);   // turn the LED on
    delay(10);               // wait for a second               << this is 10mS; use 1000 for 1 sec
    digitalWrite(ledPin[i], LOW);
    delay(10);
OK. is it not possible to make variables able to alter in this way?
No, not in C/C++.
OK well thanks for your prompt replies gents I will assign an array.
you are marked as offline for some reason AWOL ?
I am?
yea the little box under your name on the left is not green ie off line
I'm in stealth moderator mode
[quote author=matelot link=topic=232563.msg1675710#msg1675710 date=1397224145]
[code] for (i=10;i<14;i++)
    delay(10);
led not assigned.
Which format is it?
thanks.
[/quote]
This will work
digitalWrite(i, HIGH); // turn the LED on
digitalWrite(i, LOW);
delay(10);
[/code]
In fact that will wait for 0.01 of a second
That's correct, Mike, but the sequence of pins in reply #3 is not continuous.
