Hello everyone! Thank you all for reading! I am building a IP PDU (Power Distribution Unit - aka IP power stick, IP powerbar). I am using an Arduino UNO R3 and an Ethernet Shield. I have two classes in my code. One for the Outlets, the other for the Powerbar itself. I had written several lines of code and I have it working already but I came across this issue while improving the code... (or I thought I was improving it) ![]()
The Powerbar class has an array of Outlets, here is the class composition.
It also has a method getOutlet(byte index) which returns an Outlet object, the one that is in the "index" position of the array.
Every outlet in the powerbar has a name (only 8 chars + null). This name is shown in the web page under the image of the outlet. An Outlet object has a getName and setName method for getting and setting this name. But writing:
powerbar.getOutlet(0).setName("newname") doesn't change the outlet name! Don't know why!
But if I add a new method to the powerbar class setOutletName(byte index, char *newName) this one works as expected.
For better understanding I made a simplified sketch showing the issue:
class Outlet {
 public:
 Outlet(byte pin) : _pin(pin), _name{"ini"} {}
Â
 char* getName() {
  return _name;
 void setName(char *newName) {
  strcpy(_name, newName);
 private:
 byte _pin;
 char _name[9];
class Powerbar {
 public:
 Powerbar(byte pin) : _outlets{Outlet(pin)} {}
Â
 Outlet getOutlet(byte index) {
  return _outlets[index];
 void setOutletName(byte index, char *newName) {
  _outlets[index].setName(newName);
 private:
 Outlet _outlets[1];
Powerbar pbar(8);
 Outlet outlet = pbar.getOutlet(0);
 outlet.setName("name_1");
 Serial.println(pbar.getOutlet(0).getName());
Â
 pbar.getOutlet(0).setName("name_2");
 // the only way it works
 pbar.setOutletName(0, "name_3");
