What is "*" in front of a library name?
Hello
I did copy a code from a site but I won't compile.
An error at the line is reported "termistor is not declare"
Thermistor *thermistor
Also, what is "new" in this line
 thermistor = new Thermistor(A0, 3.3, 3.3, 4095, 16500, 97600, 25, 3950, 5, 20);
Main code
#include "thermistor.h"
Thermistor *thermistor;
  * arg 1: pin: Analog pin
  * arg 2: vcc: Input voltage
  * arg 3: analogReference: reference voltage. Typically the same as vcc, but not always (ie ESP8266=1.0)
  * arg 4: adcMax: The maximum analog-to-digital convert value returned by analogRead (1023 or 4095)
  * arg 5: seriesResistor: The ohms value of the fixed resistor (based on your hardware setup, usually 10k)
  * arg 6: thermistorNominal: Resistance at nominal temperature (will be documented with the thermistor, usually 10k)
  * arg 7: temperatureNominal: Temperature for nominal resistance in celcius (will be documented with the thermistor, assume 25 if not stated)
  * arg 8: bCoef: Beta coefficient (or constant) of the thermistor (will be documented with the thermistor, typically 3380, 3435, or 3950)
  * arg 9: samples: Number of analog samples to average (for smoothing)
  * arg 10: sampleDelay: Milliseconds between samples (for smoothing)
  // For 5V Arduino
  thermistor = new Thermistor(A0, 5.0, 5.0, 1023, 10000, 10000, 25, 3950, 5, 20);
  // For 3.3V Arduino
  //thermistor = new Thermistor(A0, 3.3, 3.3, 1023, 10000, 10000, 25, 3950, 5, 20);
  // For Particle Photon, Electron, etc
  //thermistor = new Thermistor(A0, 3.3, 3.3, 4095, 10000, 10000, 25, 3950, 5, 20);
  // For ESP8266 (a 10k series resistor is usually too low in this setup)
  //thermistor = new Thermistor(A0, 3.3, 1.0, 1023, 47000, 10000, 25, 3950, 5, 20);
  // For ESP8266 with improved temperature resolution...
  // Use a 1:1 voltage divider for Vcc and 47k + 10k as series resistors
  //thermistor = new Thermistor(A0, 1.65, 1.0, 1023, 57000, 10000, 25, 3950, 5, 20);
  double tempF = thermistor->readTempF();
  Serial.println("tempF=" + String(tempF));
  delay(5000);
Martin
Please do not paraphrase the error. Copy and paste the entire error listing here.
Error message
Arduino: 1.8.20 Hourly Build 2021/12/20 07:33 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
C:\Users\Utilisateur\Documents\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\Utilisateur\Documents\hardware -hardware C:\Users\Utilisateur\AppData\Local\Arduino15\packages -hardware C:\Users\Utilisateur\Documents\Arduino\hardware -tools C:\Users\Utilisateur\Documents\tools-builder -tools C:\Users\Utilisateur\Documents\hardware\tools\avr -tools C:\Users\Utilisateur\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\Utilisateur\Documents\libraries -libraries C:\Users\Utilisateur\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32wrover:PartitionScheme=default,FlashMode=qio,FlashFreq=80,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10820 -build-path C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_54999 -warnings=default -build-cache C:\Users\UTILIS~1\AppData\Local\Temp\arduino_cache_551321 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.esptool_py.path=C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -verbose C:\Users\Utilisateur\Documents\Arduino\temperature\temperature.ino
C:\Users\Utilisateur\Documents\arduino-builder -compile -logger=machine -hardware C:\Users\Utilisateur\Documents\hardware -hardware C:\Users\Utilisateur\AppData\Local\Arduino15\packages -hardware C:\Users\Utilisateur\Documents\Arduino\hardware -tools C:\Users\Utilisateur\Documents\tools-builder -tools C:\Users\Utilisateur\Documents\hardware\tools\avr -tools C:\Users\Utilisateur\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\Utilisateur\Documents\libraries -libraries C:\Users\Utilisateur\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32wrover:PartitionScheme=default,FlashMode=qio,FlashFreq=80,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10820 -build-path C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_54999 -warnings=default -build-cache C:\Users\UTILIS~1\AppData\Local\Temp\arduino_cache_551321 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.esptool_py.path=C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -verbose C:\Users\Utilisateur\Documents\Arduino\temperature\temperature.ino
Using board 'esp32wrover' from platform in folder: C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
Using core 'esp32' from platform in folder: C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
cmd /c if exist "C:\Users\Utilisateur\Documents\Arduino\temperature\partitions.csv" copy /y "C:\Users\Utilisateur\Documents\Arduino\temperature\partitions.csv" "C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_54999\partitions.csv"
cmd /c if not exist "C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_54999\partitions.csv" copy "C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\tools\partitions\default.csv" "C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_54999\partitions.csv"
Detecting libraries used...
"C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10820 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_54999\sketch\temperature.ino.cpp" -o nul
Alternatives for thermistor.h: [THERMISTOR@1.0.3 universal-thermistor-master@4.1.1]
ResolveLibrary(thermistor.h)
-> candidates: [THERMISTOR@1.0.3 universal-thermistor-master@4.1.1]
"C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10820 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\Utilisateur\Documents\Arduino\libraries\THERMISTOR" "C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_54999\sketch\temperature.ino.cpp" -o nul
"C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10820 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\Utilisateur\Documents\Arduino\libraries\THERMISTOR" "C:\Users\Utilisateur\Documents\Arduino\libraries\THERMISTOR\thermistor.cpp" -o nul
Generating function prototypes...
"C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10820 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\Utilisateur\Documents\Arduino\libraries\THERMISTOR" "C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_54999\sketch\temperature.ino.cpp" -o "C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_54999\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Users\Utilisateur\Documents\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_54999\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10820 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\Utilisateur\Documents\Arduino\libraries\THERMISTOR" "C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_54999\sketch\temperature.ino.cpp" -o "C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_54999\sketch\temperature.ino.cpp.o"
temperature:3:21: error: 'thermistor' was not declared in this scope
double Thermistor =&thermistor;
C:\Users\Utilisateur\Documents\Arduino\temperature\temperature.ino: In function 'void setup()':
temperature:25:3: error: 'thermistor' was not declared in this scope
temperature:25:20: error: expected type-specifier before 'Thermistor'
C:\Users\Utilisateur\Documents\Arduino\temperature\temperature.ino: In function 'void loop()':
temperature:39:18: error: 'thermistor' was not declared in this scope
double tempF = thermistor.readTempF();
Multiple libraries were found for "thermistor.h"
Used: C:\Users\Utilisateur\Documents\Arduino\libraries\THERMISTOR
Not used: C:\Users\Utilisateur\Documents\Arduino\libraries\universal-thermistor-master
Using library THERMISTOR at version 1.0.3 in folder: C:\Users\Utilisateur\Documents\Arduino\libraries\THERMISTOR
exit status 1
The star means you are declaring a pointer to an instance of the Thermistor class.
new Is used to create the instance
Seems you have 2 Thermistor library in your system, does the IDE pick the right one?
Hi, @arjfca
Can you please post a link to where you got the code please?
Thanks... Tom... :smiley: :+1: :coffee: :australia:
Tom George: I fouind it on Github
https://github.com/kegnet/universal-thermistor
Martin
Humm That could be a source of the problem.
I will try to see how I could resolve that
Martin
J-M-L Jakson
I did rename the othe library and the code do compile now.
Wrong value displayed, but that another task for me
Many thanks for the explanation
Martin
you should re-edit your posting with the error-message that the error-log is inside a code-section.
Then the post has a lower "height" and the content is available with the copy-function
best regards Stefan
