Depending how I read this statement from the definition of String class
toInt() Description
Converts a valid String to an integer. The input string should start with an integral number. If the string contains non-integral numbers, the function will stop performing the conversion.
I am led to believe this means Integer, not Integral number. What is an integral number anyway ? I apologise for my ignorance if such a object does exist.
Why not just call it integer in the man page ? Is it an euro-centric expression ?
Because the function can handle values that are not in the range that can be stored in an int. The actual return type from the function is a long.
The value being converted might be intended to be an int, a long, a byte, a uint8_t, a int16_t, an unsigned long, etc. All are integer types, but only one is an int.
PaulS:
But a LONG is still an integer in the mathematical domain when talking about the set of integers, and so are all the others you have mentioned.
The term "int" is strictly related to the syntax used in the programming language.
When I read the description in the String class initially, I thought it was a translation error.
greywolf271:
In my opinion 'integer' would have the same meaning and be clearer in this context. Perhaps the author is trying to avoid the possibility of you confusing this term with actual programming language data types. Or perhaps he is just being pretentious.
