Hi Guys,
I have a power supply 5v 5A.
I Will to direct connect to VIN on wemos d1 / R2, it's safe for wemos?
If no safe, what is the max voltage and Ampere if i Wanto direct connect to VIN PIN.
I'm appreciate who is suggestion.
Thanks.
Hi Guys,
Thanks.
Yes - it is safe.
Vin is for voltages higher than 5V (e.g. 7V); it goes through a 5V regulator. You need to connect the 5V output of the power supply to the 5V pin. In which case I would not connect USB at the same time.
Schematic: https://wiki.geekworm.com/images/6/68/D1_v2.0.0.pdf
WeMos D1 vs D1 R1/R2.
It's about as muddled as "Nano".
Carumba.
What seems to be worse is that one does not seem to be able to find schematics of non-current versions of boards on the official Wemos site.
Thanks brother.
am very thanks and approciate with the forum.
