What is my mistake in the code?
Hi everyone i was trying to make a color game where we have to keep in memory the color sequence emitted my the LEDs and give type in the same sequence in the serial monitor. I don’t How this part of the code is wrong so please help me out.
Here is the Program
int randomInt;
int memory[4];
char answer[4];
char takeIn;
void setup(){
  randomSeed(analogRead(0));
  pinMode(13,1);
  pinMode(12,1);
  pinMode(11,1);
  pinMode(10,1);
void loop(){
  for(int i=1;i<=4;i++){
  randomInt = random(1,5);
  switch(randomInt){
    case 1:
    blinkLed(13);
    delay(150);
    case 2:
    blinkLed(12);
    delay(150);
    case 3:
    blinkLed(11);
    delay(150);
    case 4:
    blinkLed(10);
    delay(150);
  memory[i]=randomInt;
  delay(100);
  for(int i = 1; i<=4; i++){
 while(Serial.available()){
  delay(10);
  char c = Serial.read();
  if(c == '\n'){break;}
  answer[i] = c;
  if(memory[1]==answer[1] $ memory[2]==answer[2] $ memory[3]==answer[3] $ memory[4]==answer[4]){
    Serial.println("Correct");
  else{Serial.println("Wrong");}
void blinkLed(int LED){
  digitalWrite(LED,1);
  delay(150);
  digitalWrite(LED,0);
Here is the error:
Arduino: 1.6.10 (Windows 10), Board: "Arduino/Genuino Uno"
sketch_jul31a:47: error: stray '
I know it looks like a headache please help in program
sketch_jul31a:47: error: stray ’
C:\Users\Raebel Christo\Desktop\sketch_jul31a\sketch_jul31a.ino: In function 'void loop()':
sketch_jul31a:47: error: expected ')' before 'memory'
exit status 1
stray '
“Show verbose output during compilation”
option enabled in File → Preferences.
(deleted)
And one should also remember that the index into an array starts at zero and not at one.
So the full corrected version of that line
if(memory[0]==answer[0] && memory[1]==answer[1] && memory[2]==answer[2] && memory[3]==answer[3]){
You can also use memcmp to compare the two variables.
Looks like a nice opportunity for a FOR loop
...R
I haven’t rested this since I don’t have the LED’s, but something along these lines should work and it is a little simpler:
#define PASSES  4
int randomInt;
int memory[PASSES];
char answer[PASSES];
char takeIn;
int LEDs[] = {0, 13, 12, 11, 10};
  pinMode(13, 1);
  pinMode(12, 1);
  pinMode(11, 1);
  pinMode(10, 1);
  for (int i = 1; i <= PASSES; i++) {
    randomInt = random(1, 5);
    blinkLed(LEDs[randomInt]);
    memory[i] = randomInt;
    delay(100);
    while (Serial.available()) {
      delay(10);
      if (c == '\n') {
      answer[i] = c - '0';    // Make it a numeric, not a char
  if (memcmp(memory, answer, sizeof(memory)) == 0) {
  else {
void blinkLed(int LED) {
  digitalWrite(LED, 1);
  delay(150);
  digitalWrite(LED, 0);
  delay(150);
