What is number 5 in Serial.print (_____, 5)?
Hello,
I’m following this library (Google Code Archive - Long-term storage for Google Code Project Hosting.) to get temperature and relative humidity readings. What is number 5 here?
Serial.print(hih.humidity(), 5);
If I need to store hih.humidity(),5 somewhere, is that an Int.?
Thanks,
B.
https://www.arduino.cc/en/Serial/Print
You can store the value returned by hih.humidity() (without the ,5) if you want. It appears that it would most likely be a float.
Thank you for replies. I had to store hih.humidity() in a float and then perform conversion separately to make it work, as you suggested Delta_G.
float Temper = (hih.temperature());
Serial.println(Temper*1.8+32);
  float Temper = hih.temperature();
