What is RELAY_PIN in PID_RelayOutput example
Hello. (I'm new).
I've been tinkering around with the PID_v1.h library, particularly with the PID_RelayOuput example.
I don't really understand what "RELAY_PIN 13" is for. (Internet searching didn't help)
Can please someone explain?
   PID RelayOutput Example
   Same as basic example, except that this time, the output
   is going to a digital pin which (we presume) is controlling
   a relay.  The pid is designed to output an analog value,
   but the relay can only be On/Off.
     To connect them together we use "time proportioning
   control"  Tt's essentially a really slow version of PWM.
   First we decide on a window size (5000mS say.) We then
   set the pid to adjust its output between 0 and that window
   size.  Lastly, we add some logic that translates the PID
   output into "Relay On Time" with the remainder of the
   window being "Relay Off Time"
#include <PID_v1.h>
#define RelayPin 13
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint, 2, 5, 1, DIRECT);
int WindowSize = 5000;
unsigned long windowStartTime;
  pinMode(RelayPin, OUTPUT);
  windowStartTime = millis();
  //initialize the variables we're linked to
  Setpoint = 100;
  //tell the PID to range between 0 and the full window size
  myPID.SetOutputLimits(0, WindowSize);
  //turn the PID on
  myPID.SetMode(AUTOMATIC);
  Input = analogRead(0);
  myPID.Compute();
     turn the output pin on/off based on pid output
  unsigned long now = millis();
  if (now - windowStartTime > WindowSize)
  { //time to shift the Relay Window
    windowStartTime += WindowSize;
  if (Output > now - windowStartTime) digitalWrite(RelayPin, HIGH);
  else digitalWrite(RelayPin, LOW);
[code]
It defines the pin that the relay is connected to.
Later, in setup(), the pin is configured as output.
And in loop(), you control the relay with digitalWrite.
There is NO complete statement in your code that looks like that.
There is a #define statement, that associates the value 13 with the name RELAY_PIN.
The preprocessor will search for all occurrences of RELAY_PIN and will substitute the value in place of the name, before the code is seen by the compiler.
Thank you!
I'm sorry about the confusion I might have caused with the way I worded my question.
As a follow up, while I understand that the RelayPin is on when this happens...
... I don't really understand what this means. Any help?
Hello.
I understand the library more now. I stumbled upon PID Library's author trying to explain it.
Thanks for all the help :slight_smile:
http://brettbeauregard.com/blog/2011/04/improving-the-beginners-pid-introduction/comment-page-1/
